D-50 sounding distorted, noise & creaking
gkmaia
Post by gkmaia » Thu Dec 06, 2018 6:10 am
Hi,
I just toke my D-50 out of storage after 20 years and the sound is completely distorted, noise & creaking.
Software test
- Reverb and Chorus passed
- All buttons and sliders passed
- D/A Adjustment. VR1 on the main board adjusted for minimum distortion done
Hardware - weld
- Touched up all welds on the board. For all ICs and connectors.
Hardware - TPs (mounted test points)
- TP3 D/A out - returns the distorted sound
- TP4 Lower signal - returns distorted sound
- TP5 Upper signal returns distorted sound
- TP1 Lower s/h cont - receiving 4v
- TP2 Upper s/h cont - receiving 4v
- PCM54 - receiving 12V
- 74HC - receiving 5V
I am not sure but seems that according to my TP testing I can eliminate any issues with my bender board, sliders and jacks and the distorted sign happened before those.
Any other means to test it further?
Re: D-50 sounding distorted
Post by madtheory » Thu Dec 06, 2018 9:04 pm
The DAC is actually in two parts, a 16 bit DAC and a ladder DAC for the other 4 bits (20 bit in total). You'd need to check the components in the ladder DAC.
Mooger5
Post by Mooger5 » Thu Dec 06, 2018 10:14 pm
Bear in mind the PCM54 is a mono DAC, and is putting out a multiplexed signal to save costs. The distortion you see/hear at TP3 might be normal, as it consists of both Upper and Lower alternating at a very fast rate.
I´ve had a similar problem with my D550 and the culprits were the solder joints on IC13 that had to be reworked.
I believe there should be a +5V pulse signal at TP1 and 2...
Herrare umanum est.
gkmaia
Post by gkmaia » Fri Dec 07, 2018 4:28 am
Mooger5 wrote: I believe there should be a +5V pulse signal at TP1 and 2...
I am getting a +4V on each TP1/2
gkmaia
Post by gkmaia » Fri Dec 07, 2018 4:33 am
madtheory wrote:The DAC is actually in two parts, a 16 bit DAC and a ladder DAC for the other 4 bits (20 bit in total). You'd need to check the components in the ladder DAC.
IC10 = 16 bit DAC
IC11 = 4 BIT DAC
Any idea how to test these ICs?
gkmaia
Re: D-50 sounding distorted, noise & creaking
Post by gkmaia » Fri Dec 07, 2018 6:57 pm
Touched up all welds on the board and same issue.
Ordered a new PCM54 + 74HC ICs and will replace them. Lets see what happens.
In the mean time any other ideas?
Mooger5
Post by Mooger5 » Sat Dec 08, 2018 5:32 pm
SMD joints too?
I dont have the service notes here atm but testing the chips should be easy. Just follow the input and output lines and watch with a scope or a logic probe the pulse streams. Thats the digital data or 1s and 0s in electric form.
For instance that 74hc chip has four lines going into the resistor network. Theyre the higher 4 bits. If theres 4 pulse trains the chip is most probably ok.
What tests did you run to find tp3 returns a distorted signal?u
Herrare umanum est.
gkmaia
Post by gkmaia » Sun Dec 09, 2018 5:18 am
Mooger5 wrote:SMD joints too?
I am not that trained in electronics but I will try your tips.
On TP3 I connected a headphone and the output sound distortion was there. Same way the output jack.
Mooger5
Post by Mooger5 » Sun Dec 09, 2018 9:10 pm
Well, the synth has been in storage for the last 20 years. Did you install a fresh battery and do a reset already?
Have you checked the PSU voltages?
Looked for bad capacitors?
Those routines always come first. We just assume upon reading the OP the obvious stuff is already done.
Be sure to AC couple your phones with a capacitor, before the DC ruins them.
Good luck.
Herrare umanum est.
gkmaia
Post by gkmaia » Sun Dec 09, 2018 9:32 pm
Mooger5 wrote:Well, the synth has been in storage for the last 20 years. Did you install a fresh battery and do a reset already?
Good luck.
PSU voltages are good. Replaced all capacitors on the board yesterday.
All capacitors around the DAC were fine.
There was one faulty near the CPU and was the C50.
I am waiting for my new DAC to arrive to then test everything.
gkmaia
Post by gkmaia » Fri Dec 21, 2018 8:28 am
I may have found the source of my problem but I don't actually know how to pin point it.
If I edit a patch and change the all chorus balances to 00 it sings perfectly.
That is the basic flow of data in the system:
Reverb -> dual 2-4 line decoder -> D/A converters -> Quad bilateral switch -> Filters -> Speakers
Reverb -> Chorus -> SRAM -> Chorus -> Reverb
If I balance chorus to 0 and just use reverb seems that all ICs in the main flow are OK.
But if I turn Chorus ON, then something is going wrong either on Chorus or SRAM.
Have you tested the chorus or the sram ICs signals or outputs?
Mooger5
Post by Mooger5 » Fri Dec 21, 2018 8:41 pm
Here, a similar problem is described and solved. Hope it helps.
viewtopic.php?f=5&t=78276#p741443
Herrare umanum est.
gkmaia
Post by gkmaia » Sat Dec 22, 2018 6:25 am
Mooger5 wrote:Here, a similar problem is described and solved. Hope it helps.
Thanks Mooger. I've been following this thread.
I got the reverb and SRAM ICs out of the PCB today. Put it back and did a good check on pads and traces. All 100%.
Just waiting a turned socket for the SRAM chip to arrive. Then I will put it back and test again.
Fingers crossed. If that is not it. Then I will be in trouble.
Mooger5
Post by Mooger5 » Sat Dec 22, 2018 4:34 pm
What about the chorus chip?
Herrare umanum est.
gkmaia
Post by gkmaia » Sat Dec 22, 2018 7:57 pm
Mooger5 wrote:What about the chorus chip?
I am not sure yet. Waiting my sram socket to arrive so I can attach it with a socket instead of soldering directly to the PCB.
After that I will turn it on again and test it. But till then just waiting.
It would be good to know more how to test the chorus IC with a probe or similar
