Ensoniq ESQ-1 - Distortion/Clipping problem
Q95
Post by Q95 » Thu Dec 13, 2018 1:46 pm
Hi all. I recently acquired a metal Ensoniq ESQ-1 keyboard that was a bit banged up and in need of some TLC. I cleaned it up and updated the OS chips. Only now I've noticed a really harsh warbling distortion/clipping sound happening with it.
I've read that high DCA values could cause this, but after turning DCA values way down and testing across many different patches, I've concluded that It's not the issue.
I'm thinking that it may be a power supply issue or some other internal issue but I would like some input from anyone who has experience with the ESQ 1.
I made an example recording of the distortion here: https://instaud.io/32Jb
Cheers
Hyde
Real name: Hyde
Gear: Ensoniq Mirage-EPS-EPS16-ASR10
Ensoniq SQ1-SQ1+
Akai S2000
E-MU ESI2000
Band: When Violets Turn Grey
Re: Ensoniq ESQ-1 - Distortion/Clipping problem
Post by Hyde » Fri Dec 14, 2018 7:37 pm
you replaced chips? have you tried to put the old ones back in to see if it remedies?
Makin' Noises
Q95
Post by Q95 » Sun Dec 16, 2018 6:16 pm
I haven't tried that yet but I will try it and see if it makes a difference.
