sh-101 lfo/clock rate issue
elsquirrel
Post by elsquirrel » Fri Dec 28, 2018 4:51 am
So the lfo/lock rate on my 101 is not working properly. From about about 0-75% of the slider, it stays as a super fast rate, and then the last 25% it's even faster (the led is solid color). It makes it totally unsable.
I'm not sure of the normal range of the lfo so I don't know if the fader is just not making contact for the first 3/4, or if the whole rate is way off or both.
Any advice at what I could look at here? I have a multi-meter and soldering iron.
Thanks!
Re: sh-101 lfo/clock rate issue
Post by meatballfulton » Fri Dec 28, 2018 4:38 pm
Check the voltage at the input and output of the fader. It's possible that the fader needs cleaning or replacement.
