akai s1000 - sample chopping
oldskl
Post by oldskl » Sat Mar 23, 2019 5:00 pm
i've noticed a sample cut issue on my S1000 and wondering if anyone else knows about it?
basically I cut a sample and i'm demo'ing it by pressing ENT/PLAY.
If I then select 'CUT', it doesn't cut exactly to the parameters have chosen at the end? like if the end of the sample chop is '1000', it will actually chop it at '1100'.
I am using an earlier OS version (2.2) but don't know if that's a factor
squatski
Re: akai s1000 - sample chopping
Post by squatski » Fri Apr 05, 2019 12:10 am
that's a common thing with all the s1000's don't worry, just get into the habit of cutting slightly before the peak... some samples being easier than others ie drums loops and breaks etc.
Band: Minim
Post by madtheory » Fri Apr 05, 2019 10:07 am
If you have windows PC get a SCSI card and Propellerheads Recycle, it'll chop them for you much better.
