I just got an SH-2 and it was a bit wonky but working more or less. (It was supposed to be working perfectly). It was dumb stuff like the keyboard contacts etc. But when I opened it up I found that one of the power supply caps had completely shorted and soldered-in fuse was bad. Not even sure how it was working but it was... anyway I recapped the supply, replaced the fuse, pulled and cleaned the bus bars in the keyboard. Took my measurements, got my 30v +/- and 15v +/- where I needed them, looked good, fired it up. Worked well. Everything seemed sorted.
I fired it up earlier this evening and let it warm up. When I came back to it it was frozen, unresponsive, the rate LED was solid and no sound. Ok, so I took it to the bench and checked the power supply again - and again, looks good. Still fires up unresponsive. I did not re-cap the rest of the synth nor did I make any changes at the main boards. Any ideas?
[url=https://flic.kr/p/2fBtvYu]
[url=https://flic.kr/p/TypuFE]
