Roland D-110 problem
gatd
Post by gatd » Sun Jun 02, 2019 7:24 pm
Can any one please help me ,I purchased A d-110 from ebay the problem is I can't go to any other pages in System only the first page master tune ,if I press the parameter group up button Im getting "card not ready" on the display !
Rasputin
Re: Roland D-110 problem
Post by Rasputin » Mon Jun 03, 2019 12:52 pm
Hold down the two bottom-right keys and then power on the D110. This should put you into test mode.
- Go through switch test at the very least.
Let's make sure there's nothing strange going on with the unit.
gatd
Post by gatd » Mon Jun 03, 2019 3:05 pm
all switches are ok also i forgot to add there is no card installed
Kentronix
Gear: ABL3. Waldorf Rocket, MicroBrute, Volca Bass x 2, Volca Keys, Volca Beats, Rhythm wolf, Boss DR-550, Korg Delta, Yamaha DX-11, Roland D110, Reaper DAW
Post by Kentronix » Wed Jul 03, 2019 11:08 am
I tried to emulate the issue on mine and the only way I could get that message from the system screen was by also holding the patch key down (simulating a stuck button).
I know you already stated they work but you can go into patch as normal using the button right ?
Failing that I would suggest perhaps it thinks a card is in the socket when it isnt. Do you have a card to put in and out to see if that clear it ? Do any of the tests check the card slot. If not I think I would open up and clean the card contacts and check for dust and debris.
Apart from this issue does it seem to function ok ? Can you go in and out of other non-system menus ?
Find the date of your vintage Roland gear
