M1 - Volume Slider Only Controls Right Output
footsandersen
Post by footsandersen » Fri Jul 12, 2019 6:53 pm
I picked up an M1 and the volume slider only effects the right channel output. When I turn it all the way down, the left channel does not change in level at all.
I've replaced the slider, but the issue remains. Whats the next step?
Thanks!
k
Mesmerised
Real name: Chris
Gear: Minimoog, ELKA Rhapsody, MFOS Modular, Matrix 1000, K5000S, MI Ambika, Shruthi (3x) and Anushri, Sonic Potions LXR, JX-8P, D-50, ...
Re: M1 - Volume Slider Only Controls Right Output
Post by Mesmerised » Sun Jul 28, 2019 11:57 am
I don't know if the volume slider on the M1 was analog - I assume, yes. (Is it a stereo pot?)
Sounds like the right attenuator does not have contact to ground (to pull down the signal towards ground), check for broken/cracked traces or cables.
