Roland D-50 with two dead keys
deathvalleydog
Post by deathvalleydog » Thu Jul 02, 2020 5:48 am
I love my Roland D-50, had it forever.
A while back, one key stopped working altogether, and more recently a second one has failed. I've checked around and there do seem to be some parts available, but I'm kinda clueless as to what could be the issue.
Any Roland D-50 hardware savvy folks have some advice as to the best way to diagnose the problem before I go tearing into it/throwing parts at it? :?
~DVDog
Re: Roland D-50 with two dead keys
Post by meatballfulton » Thu Jul 02, 2020 11:48 am
Does the display still work?
Do the LEDs light up and respond to the switches?
Is there any noise at the audio outputs?
Does MIDI OUT work?
If the answer to all is NO, then start by checking the power supply.
deathvalleydog
Post by deathvalleydog » Thu Jul 02, 2020 3:54 pm
Yes, everything else----display, etc, including all the rest of the keys----works fine. It's a completely functional machine, except for two keys that make no sound when you press them. The remaining 59 are good.
The two non-functioning keys also don't feel any different from the functional ones when you press them. So it seems logical that it's some kind of electronic (as opposed to a mechanical) issue. But never having seen the inside of this thing, I don't know how the mechanical action of the keys becomes an electronic signal ... some kind of electrical contact I assume? But I don't know.
That's why I'm here seeking wisdom :D
Yekuku
Post by Yekuku » Thu Jul 02, 2020 8:29 pm
Hi , what you are experiencing is a common issue for the D50.
The problem is that the rubber contact strips that are under the keys , are either dirty, worn, torn or misaligned.
In most cases they are just dirty , so you need to disassemble the keyboard and clean the contacts with rubbing alcohol.
It is all about sharing...
deathvalleydog
Post by deathvalleydog » Thu Jul 02, 2020 11:25 pm
Awesome! Thanks so much. I'll give it a try and let you know how it goes :D
fh991586
Real name: Francis
Korg Kaossilator, MicroKorg,
Yamaha Motif Rack.
Midines
Post by fh991586 » Sun Jul 05, 2020 5:01 am
Another thing to check first before dismantling anything:
Using midi, can you trigger another synth using those keys? If yes, then the problem isn't with the contact.
Using another synth to send midi signals, can you play the notes of those keys? If yes, then it's most likely the contact that causes problem.
Available for sale:
