i bought my Ensoniq SQ80 without slider caps. the volume is alway up, so thats never a problem, but i am getting tired of pushing the little data buttons up and down to get things done. the slider is intact and works, i am just looking for the slider cap. any idea who sells slider caps for the SQ80? i am not having very much luck online (Syntaur has a s**t-load of parts, just no sliders). is there a simple replacement that may work instead of an original cap? i would appreciate any leads. thanks...
in hindsight, this should probably be in HELP!...please feel free to move it...
SQ80 sliders
SQ80 sliders
Micron - MMT8 - AX60 - MPC2000 - MPC500 - S2800 - CZ3000 - SK1 (x2) - SQ80 - EA1 - ER1 - mK - Poly 800 II - BSR - Alpha Juno2 - JV1010 - TR505 - MicroQ - DX21 - RT123
- calyx93
- Gear: PPG Wave 2.2, μWave (x2), Roland JP6+V-Synth+S-220, SCI P5+600, Ensoniq SQ-80, Kawai K-3+K-3m, ARP Odyssey+Omni2, Emulator II+HD, Ensoniq Mirage.
You could probably make them yourself with some Sculpey, Fimo or other polymer clay - sculpting it into a little "chiclet" shape then creating a small slit on the bottom for the slider shaft. It might take half an hour of time, and you could choose a custom color too.
Just an idea.
Just an idea.
