Restoring yellowed plastic keys
- pangmaster
- Real name: Nathan
- Gear: Voyager, PEK, A6, FIZ, Six-Trak, Juno, CZ, and other stuff
I've got two 80s-era synths whose white keys have yellowed slightly, and I'm wondering if anyone out there has any advice about how to restore them to their original white color, or if it's even possible. I've read that soaking white plastic in 3% hydrogen peroxide might be an option to bleach the yellow out. Has anyone tried this on synth keys?
Are there other options? The keys are in great shape other than the slight yellowing, and I don't really want to replace them all as it will probably be too costly. But I do want to restore them if possible.
Cheers! 8)
Cheers! 8)
"To be human, to be fully human, is to need music and to derive nourishment from the music you hear." - Bob Moog
- V301H
- Gear: Fender The Strat, Stratocaster, Jazz Bass Rickenbacker 360-12, 320 Messenger(Mark Farner)
- Band: The Characters
Before using any harsh cleaners try cleaning the keys with dishwashing soap. If you can remove all the keys let them soak in soapy water before scrubbing with a mildly abrasive dishwashing sponge. If that doesn't do it then try something stronger.
- pangmaster
- Real name: Nathan
I've tried cleaning them with detergent and other mild stuff and no dice. I'm going to try the 3% hydrogen peroxide next.V301H wrote:Before using any harsh cleaners try cleaning the keys with dishwashing soap. If you can remove all the keys let them soak in soapy water before scrubbing with a mildly abrasive dishwashing sponge. If that doesn't do it then try something stronger.
Yeah, I was a music major so I don't want to mess with something that caustic!synth3tik wrote:I had some keys that were so yellowed I used diluted hydrochloric acid. 1 part HC to 20 parts H2O. However unless there is a chemistry degree around, I would not try this.
Letting them soak in water and disk soap is the best plan.
I'm hesitant to try the bleach because it could damage the plastic. Maybe as a last resort. Painting is something I thought of, but it could be a pain to get all the keys looking the same.Zamise wrote:Bleach or white enamel paint.
Thanks for the replies! 8)
id just leave it alone.... but let us know if you find something that works.
VINTAGE SYNTH DEALER
- https://tonetweakers.com
- pangmaster
- Real name: Nathan
I give up for the moment. A 3% hydrogen peroxide bath didn't work, and soaking in a highly concentrated Oxy-Clean solution didn't work either. My keys are very clean now, but still slightly yellow. I don't want to try bleach for fear of damaging the plastic. Painting is too much work and I've got better things to do with what little free time I have. I was hoping that this was somewhat easily solved, but apparently not. I didn't try the eucalyptus oil yet, but maybe I'll give that a go next time the yellowness gets to me again.
Cheers for the ideas!
- pangmaster
- Real name: Nathan
Re: Restoring yellowed plastic keys
Resurrecting an old thread, but it seems that some chemistry geeks have created a recipe for Retr0Bright that looks promising in restoring old, yellowed plastics. In case anyone is interested...
I tried straight-up peroxide and Oxy-Clean separately, but never used UV light. Maybe if I have a chance I'll tear apart the synths again and give this recipe a go.
- Christopher Winkels
Granted this doesn't answer the question, but I really like when a bit of yellow patina forms on my synths. I haven't had a ciggie in over six years, but despite that, my Little Phatty has a nice creaminess to the keys that makes it look more vintage than it actually is.
- EmptySet
- VSE Review Contributor
- Gear: MS20, x0xb0x, JV-1080, JX-3P, JX-8P(PG800), Juno Stage, VFX-SD, VL-1, ARP Omni I, D-50, DW6000
I haven't tried this myself, but what about laying the white keys out in the sun? It sure seems to fade everything else. Might be worth a try.
