The Official 'Secrets of the Studio' Thread!
- Joey
- Band: BLUSH_RESPONSE
So I noticed this forum was lacking one of these threads, something similar to the how to patch thread in the GS forum.
With that said, I figure we all have a few useful secrets/production tips we can share to help out everyone
I'll start off with a few easy ones:
1. For any track that is not a bass or kick drum, cut out all of the frequencies in the low end of the spectrum so no low end is taken away from the bass or kicks
2. On snares, using a compressor with a long attack and short release really helps fatten/ add punch to the sound
3. Taking a stereo pad, and then doubling it and panning each hard left and hard right (or less), and then adding a chorus/flange/phaser to one of the pads really adds some liveliness to the sound
4. Always do a mono check of your mix to make sure there is no phase cancellation
Anyone else have anything to share?
http://wearereplicants.com
Re: The Official 'Secrets of the Studio' Thread!
Kick and bass will often interfere with each other - depending on the types of sounds used, highpassing one or the other, and using a notch eq in the 200-500Hz area (i.e., filtering and cutting one to prevent overlap) will bring greater definition to both voices. Also, on the subject of EQ, I find it is a bad idea to boost the fundamental of a bass patch to bring it out, boosting where the harmonics are, or adding some light distortion will increase the perceived presence without sucking energy.
virb.com/ookpikk
- Carey M
- Gear: Akai Miniak, Fender Chroma Polaris, Moog Sub Phatty, Roland SH-101, Roland Jupiter-4, Sequential Circuits Prophet-600, Komplete 8, Reaper, iPad, beer
- Band: Nightsatan
Drive your pres, drive your comps, punish those input stages, watch those leds turn red... Just a hint of overdrive there, maybe a bit more here, instant magic!
Usually not good with heavy harmonic content, complex chords etc. But sometimes great on percussives and mono lines.
Also, experiment with parallel compression.
- CM
- CM
- tallowwaters
- Gear: LC-MS/MS
1. Push all your faders up as far as they will go
2. Put reverb on everything, especially bass and kick
3. Use a hard elbowed, 1:32 ratio compressor with the threshold set at -14 db for mastering
- shaft9000
- Real name: Dave
- Band: moneymoneymoney
- Carey M
- Band: Nightsatan
Note to self: never buy gear from "shaft"...shaft9000 wrote:record in the nude whenever possible
- CM
- tom Cadillac
- Gear: FS1R, EPS, JP8000, Kaos pad, Ineko, SP606, Mopho, MP7 and so on....
- Band: Bipolarbass
Heh! Great thread idea! I'm a newbie at studio stuff, but anyway...
1) multi track bass lines and if you can use the same synth as you did for lead or whatever - and old synth with a mono option is a good choice.
2) make a real distinction between fooling around/practicing and when you press 'record' - maybe taking your clothes off is a good idea. In record co studios you probably already have that wake-up edge of nerves because you know some studio guy is checking it all out. I get the feeling at home I can get too sleepy when I record. Jump up and down, open the window, close the curtains, take your clothes off............
"On the following day , the sorcery undespairingly continued: I changed my series, chose other sequences, cut other lengths, spliced different progressions, and hoped afresh for a miracle in sound." (Stockhausen)
- code green
- Gear: prophet 600/evolver/juno 6/alpha juno 2/bassst'n/crumar performer/jv1010/suitcase rhodes 73/ '78 gibson l6-s/'73 guild mahogany/'69 fender princeton
- Band: thermite zapruder
keep detailed notes. i have been kicking myself in the head recently for having let this habit lapse.
- brian.only
- Gear: Mono/Poly, Polysix, Crumar Performer, Juno106, Ion, CS01, K Station, DX27,77' Rhodes 88 mk1
-take breaks while recording, 3-4 min walks are great.
-keep your cords minimal and separate from power cables, mute tracks occasionally to listen for hiss and ground.
-have fun.
-try to finish that last song before you start 3 more.
-have fun.
sell me your KS5!
- piRoN
- Gear: A fair bit.
Oh yes, they're a lifesaver. My normal rule of thumb is that if I try two things in a row that just blatantly don't work then I'll go for a walk for a few minutes.-take breaks while recording, 3-4 min walks are great.
I'll also add - learn to differentiate between feeling creatively driven and just feeling bored. When I'm bored, I'll just do sampling stuff, or put together patches on my more labyrinthine gear for later use. Trying to record stuff with no real creative urge going on is just a frustrating and depressing affair.
Now as for stuff that's more relevant to the thread - Recording the acoustic noise of electric instruments is a very fun thing. Record an electric guitar through an amp sim and simultaneously mike up the strings. Either EQ the sound to pull up all those lovely transients or drop an enhancer on it (I like to use Character on the Powercore) and lay it over the top of the amped sound. Or mic up a bass guitar and lay the plucking and string noise over the top of a synth bass sound - it gives it a whole world of attitude, and you can punch it in at key points to give the bass track a bit of needed emphasis.
Recording real sounds is fun, do it as often as possible. I spent half an hour today whacking a pie tin with a wooden spoon just to add that 'little something' to a drum mix.
Use a gate with a slow attack to soften the transients of drum sounds that have too prominent an attack. It doesn't stomp all over the rest of the sound like EQing would. I use this on kicks that have a clicky attack, like a lot of analogue drum machines.
Parallel distortion is cool when you want grind in a sound but find running it through a pedal destroys all the dynamics. Put a distortion pedal on an FX send and record it to a separate track, then EQ the original and the effected tracks so that they complement each other.
Ugh... I should be able to come up with more, but it's late and I'm tired.
automate fx
- shaft9000
- Real name: Dave
too late! who did you think sold you that old matrix, anyway?Carey M wrote:Note to self: never buy gear from "shaft"...shaft9000 wrote:record in the nude whenever possible
- CM
actually, i was just being a facetious twat, since publishing one's 'secret' on an internet forum would negate it's secret status.
but you needn't worry, as it's about a 10,000+ mile trip from here to there.
you'd pay quite a fee to ship and import that far, one would imagine.
- spookyman
- Gear: cheezy machines and some cheap analog stuff
- Allways drink a glas of red wine before recording. It helps a lot to give everything.
- A Cat (synth or real) is the perfect inspirational source and brings luck in the studio.
- Work in deepness with your mix. Like on a rack. Some elements are more on the left side, other on the right, other one in front and other in the background. A real 3D mix...
- You can't "save" everything in the mix. A good sound and playing (singing) is allways better than tons of EQ and AutoTune.
- s**t In --> s**t Out.
- Listen to good records, and compare with your mix.
It is much easier to be a good equipment purchaser than to be a great musician.
- th0mas
- Expert Member
- Band: GRAVITRONIC
Something I'm realizing while recording bandmates who haven't recorded as much as I is that a lot of musicians have some ego against multiple takes. I've decided to introduce them to the analogy that they are looking at recording their part as a race (foot, car, whatever), where they feel like they're cheating if they stop and start, but it should be more like a painting.. which never gets judged by the number of strokes
- divineaudio
- Gear: far too much.
- Band: metria
a few of the things i learned while working on my last album...
1. you don't need nearly as much bass as you think you do.
2. for your whole mix to sound right, each individual track (drums/synth/bass/vocals/etc...) will NOT sound right when you solo it.
3 if you record the right sound the first time, you don't have to spend time fixing it later with excessive eq/compression/voodoo magic etc...
