Hi
I've just bought an Oberheim Stretch DX which was generally in a nice condition, but had a few switches on the Stretch side which weren't functioning properly. A bit of contact cleaner fixed one of them but two remained faulty. As the switch caps were fixed quite tightly, removing them had pulled the switches up from the board, so reasoning that the contacts between the board and the switches may have been compromised, I gave the joints a quick dab of the soldering iron - bad idea, I suspect.
Now, when the unit is turned on, all voices trigger in unison, and the display flashes up a load of vertical lines, then everything goes dead. I've tried disconnecting the stretch from the DX with no improvement. Does this sound like Ive fried something important on the main board? Does anyone know how I might go about testing for the faulty element? I'd like to see if I can sort it out before I send it for repair, as I'm skint.
Cheers
Magnus
HELP! Fried Oberheim DX
- Maschinengeist
- Real name: Steph. J
- Gear: Multimeter
Frequency Counter
Oscilloscope
Signal Generator
Logic Probe
Re: HELP! Fried Oberheim DX
Doesn't sound good. Will try to find my schematics and see what I can find.
MuzikElektronix.com
Help? See TechZone
Parts? email!
Sorry, they aren't free
MuzikElektronix.com
Help? See TechZone
Parts? email!
Thanks, that would be great. I got in touch with Paul White from the DMX files, and he told me how to disconnect the Stretch properly. After transferring the 6116 IC from the Stretch to its original place on the main board, I had some encouraging results. Now the DX alone works except for the ride and crash. Not sure what to make of that, but clearly the bulk of the problem is on the Stretch side. I'm going to keep scouring that side for loose ICs etc.
Cheers
Magnus
Cheers
Magnus
