How to connet 606 707 and 303.
acidbrother
Gear: many stuff
Post by acidbrother » Sun Jun 06, 2010 4:09 am
Do I need a special din-sync cable to connect the 606 707 and the 303 ?
space6oy
Re: How to connet 606 707 and 303.
Post by space6oy » Sun Jun 06, 2010 4:21 am
most MIDI cables will transmit din sync no problem. you're going to have to get a splitter to chain those three though, they each only have one din sync jack.
acidbrother
Gear: many stuff
Post by acidbrother » Sun Jun 06, 2010 4:23 am
What is a splitter?
space6oy
Post by space6oy » Sun Jun 06, 2010 4:42 am
a Y cable or a box w/ multiple outs, something like this:
http://keyboards-midi.musiciansfriend.c ... sku=702504
thought HOSA made a midi Y cable but can't find it, pretty sure they're out there though.
acidbrother
Gear: many stuff
Post by acidbrother » Sun Jun 06, 2010 7:35 am
Thanks I will check around.
ninja6485
Band: Subliminal Sea
Post by ninja6485 » Sun Jun 06, 2010 5:04 pm
if all else fails, the msq-100 is dirt cheap and can take midi in and trigger sync out. not as cheap as finding a y cable tho. i wonder if there's a mod for the 707 to allow it to do both at the same time wile slaved...
Z
Post by Z » Sun Jun 06, 2010 5:26 pm
space6oy
Post by space6oy » Sun Jun 06, 2010 8:49 pm
ninja6485 wrote:if all else fails, the msq-100 is dirt cheap and can take midi in and trigger sync out. not as cheap as finding a y cable tho. i wonder if there's a mod for the 707 to allow it to do both at the same time wile slaved...
not sure about positioning within the housing, but yes, wiring in a second din sync line would be pretty easy, but only for the two to both run input or output at the same time. so slaving it via midi then running two din sync outs would be doable, but that wouldn't solve the 606-707-303 lineup. and obviously you could never simultaneously slave it to two din sync ins.
jaypodesta
Post by jaypodesta » Sun Jun 06, 2010 8:57 pm
Syn mentioned these in another thread:
http://www.kentonuk.com/products/items/ ... sync.shtml
space6oy
Post by space6oy » Sun Jun 06, 2010 8:59 pm
nice, Y cable at the end of that list.
acidbrother
Gear: many stuff
Post by acidbrother » Mon Jun 07, 2010 2:49 am
So would the Y cable be my best option or does the midi solutions box work? it is more expensive though.
space6oy
Post by space6oy » Mon Jun 07, 2010 5:43 am
new Y cable or a used midi splitter box would be the most affordable options. Y cable is the most simple since it doesn't require power. if it's just those three & you won't be looking for more midi connections, that's the best way to go.
Syn303
Gear: Quite a bit...
Band: Syn303
Post by Syn303 » Mon Jun 07, 2010 11:03 am
This small UK company http://www.systemj.co.uk/sysj1.html makes din-sync splitter boxes, the one below is £19.95. Pretty cheap to me, they also supply din-sync24 cables as well. It requires no power supply as it is passive.
acidbrother
Gear: many stuff
Post by acidbrother » Wed Jun 09, 2010 1:33 am
Syn303 wrote:This small UK company http://www.systemj.co.uk/sysj1.html makes din-sync splitter boxes, the one below is £19.95. Pretty cheap to me, they also supply din-sync24 cables as well. It requires no power supply as it is passive.
I might just have to get this! Thanks
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Wed Jun 09, 2010 2:56 am
I can make a sync box splitter for you if you buy the parts needed. I made my own twice now. I gave my first one to a friend. h**l, even if you're half assed with a soldering iron, you can do it yourself.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
