physical MIDI cable specs
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Wed Dec 15, 2010 2:53 pm
OK so I am making a 'double adaptor' midi plug because I have 2 devices with only a midi IN port on them... I know it is not 'recommended' but it works when I dont need to send different data to them and the distance is less than 20cm.
Anyhow after I spent all the time soldering up the wires to the 5 pins + ground for each 5-pin DIN plug I remembered something..
I only have to use 2 pins + the ground when I send MIDI out of my Arduino... it works fine.
But then I cut open a dead midi cable I had, and it has all 5 lines.
So that leaves me with 2 questions:
1) Do I only have to use the 2 pins + ground to make my own midi cables? Or do some devices send midi down all 5 cables therefore need them?
1) If I only need 2 + ground, then why the h**l did they choose FIVE pin din sockets to be the midi standard? expandability? lack of foresight?
b3groover
Real name: Jim
Band: THEO
Re: physical MIDI cable specs
Post by b3groover » Wed Dec 15, 2010 6:07 pm
Post by madtheory » Wed Dec 15, 2010 6:08 pm
Two pins and the ground is the correct wiring for a MIDI cable, anything else can cause problems. A lot of MIDI cables are not actually MIDI cables at all, but DIN audio cables rebadged.
schmidtc
Post by schmidtc » Wed Dec 15, 2010 6:08 pm
All midi I'm aware of only uses 3 of the 5 pins.
Post by meatballfulton » Wed Dec 15, 2010 6:15 pm
The actual cabling spec indicates that pins 1 and 3 are never connected.
Why did they choose 5 pins? At the time of MIDI 1.0 it was thought that future extension of the spec would make use of the extra pins. This has not happened yet.
Synthaholic
Post by Synthaholic » Wed Dec 15, 2010 9:27 pm
Another interesting tidbit about the 5-pin DIN connectors used for MIDI: they are the same connectors that the original IBM PC and PC/AT used for the keyboard. Many "clone" PCs even into the mid 90s used this same "AT" keyboard connector. Why is this relevant? Well, one time years ago I needed a longer MIDI cable for something, and I was able to use an AT keyboard extension cable to do the trick.
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Thu Dec 16, 2010 4:45 am
thanks guys!
Funny how such a simple thing can have quite a complicated background.
Altitude
Post by Altitude » Thu Dec 16, 2010 5:57 pm
madtheory wrote:Two pins and the ground is the correct wiring for a MIDI cable, anything else can cause problems. A lot of MIDI cables are not actually MIDI cables at all, but DIN audio cables rebadged.
Also worth mentioning that the ground is only connected on the midi output, never on a midi input (It's just for shielding so its open on one end)
cornutt
Gear: 6th
Post by cornutt » Thu Dec 16, 2010 7:43 pm
Also, DIN sync a la the Roland X0X drum boxes use the two pins that MIDI doesn't use. So some MIDI cables are also sold as DIN sync cables.
Shreddie
Gear: Alesis Andromeda, Fusion 8HD: ART SGX Nightbass SE: Kawai K5000s: Yamaha A3000 V2, EX7, FS1R, PSS-480 (Don't laugh, it rocks!) and 4 planks.
Post by Shreddie » Mon Dec 20, 2010 1:20 am
If you're planning on making your own midi cables, just use 2 core mic cable... It's of a higher standard than most off the shelf midi cable so is useable for surprisingly long runs, I've read that upto 70m is possible.
Hybrid88
Post by Hybrid88 » Mon Dec 20, 2010 8:21 am
Personally I'd rather get something like this for splitting purposes;
http://cgi.ebay.com.au/Touchprone-1x3-M ... 2554d7632b
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Wed Dec 22, 2010 1:06 pm
wow.. There is no way I would ever pay $55 for that thing.. or even $25 for that matter. That box doesn't even seem to be powered (meaning it's doing exactly the same thing my device is.. but costs 10x as much)
Post by madtheory » Wed Dec 22, 2010 2:30 pm
Actually it does claim to be powered, it draws power from the MIDI line. That's entirely possible, there's 5V there to play with. In fact it's not possible to split the MIDI signal 3 ways without power.
Your passive splitter will work, but not with every piece of gear.
Hybrid88
Post by Hybrid88 » Wed Dec 22, 2010 2:50 pm
Fair enough, it's really not much to outlay though for what your getting. Difference is the $55 one is designed to work, plug and go. Whereas your solution is a bodge solution, that's not to critisise sure it might work sometimes, but I cant see it being very reliable... YMMV tho :)
cartesia wrote:wow.. There is no way I would ever pay $55 for that thing.. or even $25 for that matter. That box doesn't even seem to be powered (meaning it's doing exactly the same thing my device is.. but costs 10x as much)
cartesia
Gear: Octatrack
Bass Station 2
Band: TBA
Post by cartesia » Thu Dec 23, 2010 2:30 pm
there may be a few old devices it wont work with, but it's not gonna be like a half the time it works, half the time it doesnt thing, so yeah.. for me, it is perfect (more than 1 device that only has a midi IN port)
