Free gritty analog monosynth VST
- Jabberwalky
- Gear: A hybrid of vintage and modern junk
- Band: Variar
Re: Free gritty analog monosynth VST
Thanks for trying it out Guerra! The VST has taken the side burner as I've been concentrating on getting an EP out, but I do plan on considering your suggestions. Joshy, I'm not sure what is causing that as it seems everyone else has no problems with it. Synthedit is not something you need to run the vst, as its a standalone .dll. What DAW and platform are you using?
You know what would be absolutely incredible, that almost no VST has ever had (at least that I know of)? The ability to have a clock in for the S&H. I've never seen a VST that has a clock in for the S&H, so it's impossible to create repetitive loops with it. It would be incredible to finally have a VST that can make repetitive S&H loops.
