What is a sequencer?
Hello all, I'm new to playing synth and was wondering what is a sequencer and what does it do, please.
Re: What is a sequencer?
it sends note data only.
the power is that this note data can be used on a wide range of instruments.
if you are talking a 'midi sequencer', then it can play any other instrument with a midi input that reacts to note data.
you can use one sequencer, set at one master tempo, to drive even a multitude of midi instruments, drum machines, other sequencers, etc, and control it all from the main sequencer and make sure they are all in time with each other.
though a sequencer's basic and primary function is controlling and sending note data, it is often integrated with ways to produce sounds in the same box or whatever, see MPCs, Electribes, most software DAWs (Ableton Live, Logic, Cubase, FL Studio etc) - examples of sequencers that produce no sounds of their own include the Alesis MMT8 and any number of rack step sequencers (usually loops of only 8-64 steps/notes... Future Retro Orb/Mobius, Doepfer MAQ16/3, Moog 960 etc)
beyond that, search for YouTube videos of sequencers and you'll figure it out
- balma
- Real name: Mauricio
- Gear: DSI Tempest/Prophet 08/Roland V-Synth/Ensoniq Fizmo/E-mu MP7-XL7/Electribe ESX1/Radias/Waldorf MicroQ
What the h**l is a synth?skullcrusher wrote:Hello all, I'm new to playing synth and was wondering what is a sequencer and what does it do, please.
https://soundcloud.com/balma
You can you an analog sequncer for a lot more then notes.
All kinds of control and even as a oscillator
Gear: Minimoog, Mother-32, Roland MC-202, TB-303, (Boss) DR-110, TR-505, TR-808, Alpha Juno 2, Jupiter-8, Oberheim SEM, .com/oakley/moon/mos-lab/STG/Sputnik/MegaOhm-modular & Microbrute
- balma
pleace bi mor especificJJQ wrote:You can you an analog sequncer for a lot more then notes.
I use mine to control envepole attack for filters (or just filtersbalma wrote:pleace bi mor especificJJQ wrote:You can you an analog sequncer for a lot more then notes.
Or
Thank you all for help
Ooh. Just noticed my weired typing
how is babby formed?
how girl get pragnent?
- Z
I always use the analogy that a MIDI sequencer is to music composition as a word processor is to writing.
You input note data (pitch, duration, velocity, etc.) and manipulate it within the software (be it a computer or hardware sequencer), cut & paste similar to entering text into a word processor (changing font type & size, etc.). Once you have your composition to your liking, you have the sequencer play your instruments and record them to tape (or preferred digital format) just like you would print your word processor document.
There is much more that can be recorded into a sequencer, I just wanted to give you the basic jist of things. Just to reiterate, a sequencer records DATA, not audio.
Notice I described a "MIDI Sequencer". Analog sequencers output control voltages which can be used to contol oscillators' pitch, filters' cut-off frequency or anything that can accept a control voltage.
- balma
Sequencers can have many applications on the music composition. Most common of them and for somebody who is starting with synths like you , is to allow you to compose music, storing the notes you play and then, hitting play and you hear what you just play.skullcrusher wrote:Thank you all for help
Is like recording an audio tape, but with the huge difference; that you can go back and modify and edit almost anything that you recorded.
What they record, is an EVENT on the synth's memory, like in the way you record sentences when programming computers.
This event, orders to the synth: hey man! play the note C2, during XX measures; at the velocity of 96; at the bar xx xx xx,...
Then, you can record a bass, a syth line, drums; and play all together.
In other words, sequencers are making regular musicians going jobless
- Zamise
- Gear: Rollhand P00
- Band: Quantum-Source
Not all sequencers should be called sequencers IMHO. They should be calling some of them more along the line of something like a programmable arpeggiator or a programmable-stepped LFO. Those are found more on performance synths, or just one part of a song, which will have very limited note or event storage capacity, usually like only 16 steps per voice, key or sequence. A decent or true sequencer, what I'd consider able to make whole songs with, will have a lot more note and event storage capability across multiple tracks or channels for making more full and whole sounding songs. A full blown sequencer will have at least 16 tracks/channels for simultaneous sequencing and or playback. You should be able to sequence all parts of a song with a sequencer. Parts may contain a programmable sequenced/arpeggiated part tho seperate from the main sequencer, so you'd then be sequencing a sequencer. If you are looking to do whole songs, and not just sequencing one part of a song, make sure it is a full blown sequencer or at least can sequence multiple tracks/channels. The differences between a real sequencer, programmable arp, or even "Analog style sequencer" is and can be confusing, especially for noobs. It is good to know the differences between them ahead of time, it'll save you some headaches, and not feel like you got ripped off so much when you get a synth that says it has a sequencer instead of a sequencer that includes synth parts.
