ARP 2600 questions: patch cables / voltage
my friend is letting me borrow an ARP 2600 that hasn't been used in years. just curious, will it take normal 1/8 mini or something else? i assume it's easy enough to wire up my own, but are there any caveats? I have a ton of doepfer cables. can it use those? what about inter-voltage issues between a 2600 and a eurorack?
- CZ Rider
Re: ARP 2600 questions: patch cables / voltage
Unless it is modified,an Arp 2600 used Switchcraft Tini-jax. They are .141" and very close to the 3.5mm that euro systems use. YMMV as many users swap in 3.5mm without any problems. Usually the problem is the tip on the 3.5mm sometimes does not have the correct width to disengage the switching type 42 Switchcraft jacks. Or touching a patch cord might trigger an intermittent connection. But it should do no harm to use 3.5mm patch cords with a Tini-jax system like the Arp/Aries/Buchla. But I would not plug a .141" Switchcraft patchcord into a 3.5mm euro jack. The Tini-jax are about 3.58mm dia.username wrote:my friend is letting me borrow an ARP 2600 that hasn't been used in years. just curious, will it take normal 1/8 mini or something else?
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
THANK YOU. This explains EVERYTHING!!! I was sure my jacks had just become loose with age!CZ Rider wrote:Unless it is modified,an Arp 2600 used Switchcraft Tini-jax. They are .141" and very close to the 3.5mm that euro systems use. YMMV as many users swap in 3.5mm without any problems. Usually the problem is the tip on the 3.5mm sometimes does not have the correct width to disengage the switching type 42 Switchcraft jacks. Or touching a patch cord might trigger an intermittent connection.username wrote:my friend is letting me borrow an ARP 2600 that hasn't been used in years. just curious, will it take normal 1/8 mini or something else?
- xpander
- Gear: UltraProteus, Xpander, 200e, Minimoogs, Radias, Prophet VS, PolyEvolver, Arp 2600
i had no idea! i've got a bunch of tini-jax cables for my Buchla, i'll give 'em a try.
- Automatic Gainsay
Are these things still made? Does anyone have a source for them?xpander wrote:i had no idea! i've got a bunch of tini-jax cables for my Buchla, i'll give 'em a try.
- Gear: ARP 2600
EMU SSM Card Kit
Prophet 600
Evolver
ESQ-1
Juno 6
Alpha Juno 2
JV-1010
Crumar Performer
EMU e6400 ultra
MPC2000xl
SK-1
SK-5 - Band: Thermite Zapruder
Did you ever find a source for them?Automatic Gainsay wrote:Are these things still made? Does anyone have a source for them?xpander wrote:i had no idea! i've got a bunch of tini-jax cables for my Buchla, i'll give 'em a try.
- ppg_wavecomputer
- Expert Member
- Gear: more keys than hands (and feet)
- Band: ['ramp]
- Location: teutoburg forest, eastern westphalia, germany
This, plus corroded connectors within the switching jacks which hardly make any contact at all -- or too much contact which can render entire sections of the instrument unusable (i. e. when unplugging, the jack still behaves as if something was plugged in).CZ Rider wrote:Unless it is modified,an Arp 2600 used Switchcraft Tini-jax. They are .141" and very close to the 3.5mm that euro systems use. YMMV as many users swap in 3.5mm without any problems. Usually the problem is the tip on the 3.5mm sometimes does not have the correct width to disengage the switching type 42 Switchcraft jacks. Or touching a patch cord might trigger an intermittent connection. But it should do no harm to use 3.5mm patch cords with a Tini-jax system like the Arp/Aries/Buchla. But I would not plug a .141" Switchcraft patchcord into a 3.5mm euro jack. The Tini-jax are about 3.58mm dia.username wrote:my friend is letting me borrow an ARP 2600 that hasn't been used in years. just curious, will it take normal 1/8 mini or something else?
I had nearly all jacks replaced on my 2600. Now it's working quite the way it should -- sort of.
Stephen
https://ramp1.bandcamp.com/
- Gear: ARP 2600
EMU SSM Card Kit
Prophet 600
Evolver
ESQ-1
Juno 6
Alpha Juno 2
JV-1010
Crumar Performer
EMU e6400 ultra
MPC2000xl
SK-1
Are the new jacks Tini-Jax and, if so, do you have a source for the cables?ppg_wavecomputer wrote:
Stephen
- ppg_wavecomputer
- Expert Member
- Band: ['ramp]
The new jacks were manufactured by Switchcraft but they were not called Tini-Jax. It was the standard 1/8" type of jack that works well with my other cables (original ARP cables and self-made ones).thermite zapruder wrote:Are the new jacks Tini-Jax and, if so, do you have a source for the cables?ppg_wavecomputer wrote:
Stephen
Stephen
- piRoN
- Gear: A fair bit.
Digikey still has Tini-Plug and Tini-Jax in stock, if you're up for rolling your own cables.thermite zapruder wrote:Did you ever find a source for them?Automatic Gainsay wrote:Are these things still made? Does anyone have a source for them?xpander wrote:i had no idea! i've got a bunch of tini-jax cables for my Buchla, i'll give 'em a try.
See here.
- analoglsd
- Real name: Lance
- Gear: Buchla Music Easel, TE OP-1, Korg MS-20, Yamaha RS-7000, Effects Pedals
The cables labeled as audio cables are the ones as well.
http://www.buchla.com/product-category/accessories/
