Prophet-5 mono output only sounds in left speaker/headphone
iProg
Real name: Carl
Gear: Prophet-5, Korg PolySix, Roland D-50, JV-1080
Band: ArtWithHeart
Post by iProg » Thu Dec 15, 2011 9:55 am
When plugging in monitors/speakers/headphones into the P5, there is only sound from the left unit. What kind of problem is this? Has anyone encoutered it recently? Suggestions on solutions please!
snod_donkey
Re: Prophet-5 mono output only sounds in left speaker/headph
Post by snod_donkey » Thu Dec 15, 2011 10:44 am
I wasnt aware there's a stereo output
My P5 has a single jack out and no headphone socket
Post by madtheory » Thu Dec 15, 2011 12:46 pm
You need to use a mono jack plug instead of a stereo one. The reason is some mono outputs will connect to both the tip and the ring. Looks like the one in your P5 connects to tip only.
iProg
Real name: Carl
Band: ArtWithHeart
Post by iProg » Thu Dec 15, 2011 1:21 pm
madtheory wrote:You need to use a mono jack plug instead of a stereo one. The reason is some mono outputs will connect to both the tip and the ring. Looks like the one in your P5 connects to tip only.
But it has worked before! This confuses me. I just put the headphone jack into the audio out socket and only the left headphone sounds....weird.
Post by Stab Frenzy » Thu Dec 15, 2011 2:33 pm
No that's normal behavior for an output.
