Prophet 12 module or Pro 2
White
Gear: Quite a few synths
Post by White » Tue Jul 22, 2014 10:39 am
Which one? And does the latest software upgrade for the Prophet rack bring it in line with the Pro 2? Finally, can someone explain paraphonic mode?
Duncan J. White + quite a few synths
http://www.myspace.com/stickman76590059
pflosi
Re: Prophet 12 module or Pro 2
Post by pflosi » Tue Jul 22, 2014 10:53 am
White wrote:Finally, can someone explain paraphonic mode?
In b4 AG!
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Tue Jul 22, 2014 11:53 am
no,the softwarte upgrade for the Prophet 12 rack isn't going to make it match the Pro 2.... the PRo 2 has an extra, different (non-Curtis) analog filter in it.
Gear: Live 9, Logic Pro X
Post by meatballfulton » Tue Jul 22, 2014 1:29 pm
I've been seeing deals on the Pro12 module here and there for as little as $1600, making it cheaper than the Pro2 at $2000.
Pro12 lacks the sequencer which is a pretty big deal and as mentioned above, the LPF is Curtis based so will sound different. Of course, it's polyphonic which is the biggest difference...do you want a polysynth or not?
Paraphonic means that there is only one filter rather than one per oscillator. So you can play four notes at a time but filter articulation is more limited than in a true polyphonic synth. There's also only one oscillator per note vs. four per note in mono mode or in the Pro12.
moremagic
Real name: A.M.
Post by moremagic » Tue Jul 22, 2014 6:20 pm
well, 2 filters, but yeah, what he said ^^^
erics2s
Post by erics2s » Sun Aug 17, 2014 6:35 pm
Aside from the filter type and the robust sequencer/arpeggiator implementation of the ProTwo, is the sound engine from the P12 and P2 the same or nearly the same? Is owning both redundant?
Tronsynth
Post by Tronsynth » Wed Oct 29, 2014 10:10 am
I also in the same spot as OP.I don't know which synth to buy,the Prophet 12,or the Pro2.
Post by Stab Frenzy » Wed Oct 29, 2014 11:37 am
Tronsynth wrote:I also in the same spot as OP.I don't know which synth to buy,the Prophet 12,or the Pro2.
Well do you want a monosynth or a polysynth?
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Thu Oct 30, 2014 7:57 am
Quite easy really. Do you want 12-note polyphony or just mono? That's your choice.
Are you more of a piano/organ type player that likes lots of chord progressions and riffs, or do you just control it via ableton live and MIDI?
