EMU 4000 Hard disk questions
Real name: Unpronounceable
Band: Eridani V
Re: EMU 4000 Hard disk questions
Post by Ashe37 » Mon Apr 27, 2015 11:32 am
Marco Koeller wrote:On my research for Samplers with internal harddisks, i found a thread where a user mentioned a SCSI-to-PCI adapter. Dont know, if such a thing exists, but if, it could be another possibility to mount younger harddisks than the SCSI ones.
My first PCs had SCSI drives, so i remember they were pretty loud and noisy back in that time. The Quantum HD which is mounted inside my ESI-4000 doesnt amke any noise, by suprise :)
SCSI to PCI adapter is what you use to put a SCSI hard drive into a PCI computer.
There are PATA and SATA to SCSI adapters, but they cost a bundle.
Marco Koeller
Real name: Marco Koeller
Gear: Akai S-2000, Akai S-1100, EMU ESI-4000, Roland D-50, Roland D-110, Roland JD-800, Roland TR-626, Roland TR-505, Roland MC-303, Korg DW-8000
Band: Smooth Genestar, Smooth
Post by Marco Koeller » Mon Apr 27, 2015 11:36 am
Ashe37 wrote:
Marco Koeller wrote:SCSI to PCI adapter is what you use to put a SCSI hard drive into a PCI computer.
I know that :lol: :geek:
No, i meant another thing. A user reported 2 or 3 years ago, he had found an adapter which makes a PCI connection out of an existing SCSI connection. As said, dont know if its true, but that guy posted a link for this adapter, and it seemed to be a "real" product. Too bad i didnt bookmarked it. I tried Google to find this topic again, but without result.
Music is an universal language, spoke and understood by all....
Free audio netlabel http://www.cyan-music.com
Deep House and Dubtechno http://www.cyan-music.com/smooth
Lounge and Chillout http://www.cyan-music.com/smooth-genestar
Band: Eridani V
Post by Ashe37 » Mon Apr 27, 2015 11:39 am
Never heard of anything like that. Going so would basically require a computer hosting a scsi bus and doing data translation.
Marco Koeller
Post by Marco Koeller » Mon Apr 27, 2015 11:47 am
I think you´re right. It was something like this that guy posted:
http://www.cable-connector88.com/product.asp?proid=4326
But i dont think that it is that simple to make a PCI connection out of a SCSI connection.
My feeling says, using such a plastic adapter would be way too easy. Especially if you know SCSI and its behaviour.
synthroom
Real name: Kirk
Post by synthroom » Mon Apr 27, 2015 2:17 pm
Marco Koeller wrote: The Quantum HD which is mounted inside my ESI-4000 doesnt make any noises, by suprise. Only when the HD starts up, but after that, its really quiet.
Marco - do you have any kind of extra PSU for the SCSI HD? I've read that the ESI PSU is not strong enough to handle an internal HD.
Marco Koeller
Post by Marco Koeller » Mon Apr 27, 2015 2:44 pm
synthroom wrote:Marco - do you have any kind of extra PSU for the SCSI HD? I've read that the ESI PSU is not strong enough to handle an internal HD.
Hm, thats a real good question. To be honest, i never looked inside as i bought this unit as it was. Maybe i could ask the guy who sold me this unit. He is from germany and specialized on upgrading samplers by EMU. For example, he shippes out the EMUs with the 15 GB harddisk already mounted, and onto the harddisk there is the complete EMU library pre-installed. Like all sound by Planet Phatt, Orbit and some other devices by EMU.
No problem. I will ask him and let you know when he answered.
Marco Koeller
Post by Marco Koeller » Wed Apr 29, 2015 5:09 pm
I am back with the infos i promised to share here. I contacted the guy i bought the ESI-4000 with the internal 15 GB harddisk from. He said, the internal HD is connected to the internal power bus of the ESI-4000 and that no additional power supply has been needed. Maybe this answer is helpful to you.
Greetings,
Marco
synthroom
Real name: Kirk
Post by synthroom » Wed Apr 29, 2015 6:17 pm
Marco - thanks for checking. Does your ESI also have an internal Zip drive as well as the HD, or a standard floppy. I have an ESI-4000 Turbo that came with the built-in Zip so I don't haven to overload it adding in a HD as well.
Marco Koeller
Post by Marco Koeller » Wed Apr 29, 2015 7:14 pm
No, the internal HD is placed where the floppy drive was placed before. So, in fact, my ESI-4000 has only an internal HD, which is great because the OS is booted faster from the HD than from the floppy.
Because of the internal HD there is no further drive like Zip drive or anything else. The HD fits all of my needs.
gmeredith
Band: Warning Will Robinson
Post by gmeredith » Thu Apr 30, 2015 3:31 am
SCSI to PCI adapter?
Are you sure you're not meaning SCSI to IDE adapter? ie hooking up a normal IDE hard drive to an EMU SCSI port using an adapter?
The SCSI to IDE adapter is what's in my SCSI to CF card reader in my ESi4000. It has 2 boards in it - the SCSI to IDE board, and the IDE to CF board. They just plug in to each other as part of the whole unit, which is cased in a floppy drive case to directly replace the Esi's floppy drive, and has a CF slot in the front. If I wanted to, I could disconnect the IDE to CF reader from the SCSI to IDE board, and connect an IDE hard drive to it.
Wouldn't want to though - that's the whole point of SCSI to CF adapters - ditch the moving parts/noise and get faster load times as well :)
Post by madtheory » Thu Apr 30, 2015 4:59 am
Marco Koeller wrote:which is great because the OS is booted faster from the HD than from the floppy.
Except that the OS is in ROM not on disc. Under your Turbo effects board, in two chips 3.02 being the final rev.
Marco Koeller
Post by Marco Koeller » Thu Apr 30, 2015 9:41 am
gmeredith wrote:Are you sure you're not meaning SCSI to IDE adapter? ie hooking up a normal IDE hard drive to an EMU SCSI port using an adapter?
You´re right. That was what i meant originally. My fault. I meant IDE instead of PCI.
Band: Eridani V
Post by Ashe37 » Thu Apr 30, 2015 9:44 am
Like i said... PATA (Parallel ATA) = IDE, Serial ATA is what followed it.
Marco Koeller
Post by Marco Koeller » Thu Apr 30, 2015 9:44 am
gmeredith wrote:Wouldn't want to though - that's the whole point of SCSI to CF adapters - ditch the moving parts/noise and get faster load times as well :)
I guess you have that CF device by Lotharek, right? Recommendable?
Marco Koeller
Post by Marco Koeller » Thu Apr 30, 2015 9:49 am
madtheory wrote:Except that the OS is in ROM not on disc. Under your Turbo effects board, in two chips 3.02 being the final rev.
Also right. I forgot this as i am used to boot the OS on my other AKAIs from floppy drive.
