Line out issues
dkhbrit
Line out issues
Post by dkhbrit » Sun Mar 01, 2015 2:43 am
Loving my Legacy M1 but I just can't get it to sound right. I've tried using the PC line out but it's very weak and buzzy. I've tried a USB interface and the sound seems garbled somewhat and is still weak. I am using a decentj enough Mackie mixer and cables are OK (I can take the same routing from the headphone jack of my Microkorg and it sounds great). Do I need a soundcard in my PC?
Re: Line out issues
Post by meatballfulton » Sun Mar 01, 2015 3:28 pm
First things first.
-- Are you running it standalone or inside a DAW?
-- How does it sound if you listen to it over headphones connected to the PC?
-- Is this a Windows machine?
max badwan
Real name: Max
Re: Line out issues
Post by max badwan » Sun Mar 01, 2015 10:28 pm
meatballfulton wrote:First things first.
-- Is this a Windows machine? (I'm pretty sure it's a PC, you don't need to buy a sound card if it's a Mac.)
Add to that:
which OS are you running?
which version of Korg Legacy is it (32/64)?
dkhbrit
Re: Line out issues
Post by dkhbrit » Mon Mar 02, 2015 12:52 am
Standalone
Not too bad but kind if distorted
Windows 8
max badwan
Real name: Max
Re: Line out issues
Post by max badwan » Mon Mar 02, 2015 1:42 am
Are you running the 32 or 64 bit version (Korg)? Have you checked the audio tabs under preferences?
dkhbrit
Re: Line out issues
Post by dkhbrit » Mon Mar 02, 2015 3:01 am
I'll check next time I'm up in my room. Pretty sure it's 64.
Based on what version it is what do I tweak? Like I said, all other sound sources out of this PC sound fine. It's very odd.
Real name: Unpronounceable
Band: Eridani V
Re: Line out issues
Post by Ashe37 » Mon Mar 02, 2015 4:09 am
dkhbrit wrote:I'll check next time I'm up in my room. Pretty sure it's 64.
Define 'all other sound sources'... are you talking other VSTs? or things like playing PC games, videos and music?
max badwan
Real name: Max
Re: Line out issues
Post by max badwan » Mon Mar 02, 2015 4:09 am
Have a look at the sample/bit rate on the app, and on your sound card - there may be a mismatch; and, have a look at the latency settings - there may not be enough buffer.
dkhbrit
Re: Line out issues
Post by dkhbrit » Mon Mar 02, 2015 1:31 pm
Don't have other VSTs but videos, music all sound fine on the PC.
Appreciating the help guys. Thanks.
Band: Eridani V
Re: Line out issues
Post by Ashe37 » Mon Mar 02, 2015 1:37 pm
Yep, you need to turn up the latency on your audio interface, that's what it is.
dkhbrit
Re: Line out issues
Post by dkhbrit » Fri Mar 06, 2015 6:09 pm
OK, all seems to be working now. I was using a Behringer UCA222 interface. I dug out my 1818VSL and tried that instead and it worked great once I'd updated the firmware.
Thanks for all your wisdom
