3-Oscillator Per Voice Polysynths??
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
A few years back I spent the day with a friendly guy in Paris at his studio stacked high with just about every synth ever made - including a curious orange megaphone and a flock of Small Stone Phasers...
During a remarkably long conversation we got on to the subject of the musicality of various oscillator configurations in polysynths. He raised a point that I have sometimes touched on that in non-sync'd configurations three oscillators per voice produce more musical results than the more commonly found two as the effects of phasing and beating in dual oscillator synths can often be rather cyclical/mechanical leading in extreme cases to null points. Having three oscillators produces a much more complex and natural effect more a likened to the strings on a piano beating or a natural complex ensemble effect (which, incidentally were almost always triple parallel delay effects in string synths).
But it got me thinking.. just how many 3-Osc per voice analog /hybrids polysynths were ever produced??...
NEW CRITERIA: Marc raised a good point and after some contemplation I've decided to bar all DCO and Wavetable Synths unless they can be proven to have multiple free-running HF master oscillators.
Caveat: I've decided to allow VCO based synths with layering facilities to obtain 3 free running oscs.
Obviously the Memorymoog fits the criteria but I'll be darned if I can think of many more bar the Korg PS-3300 and its direct descendants...
List of Triple Free-Running Oscillator Polys as it currently stands:
Definitely fit the criteria:
Memorymoog
*Korg PS-3300
*Korg PE-2000
*Korg Lambda
*Divide down but feature multiple free-running master oscillators.
Futuresonus Parva?
Can Achieve Same Effect Through Layering: (All VCO based so definitely fit the bill for free running oscs)
Oberheim OB-8
Oberheim OB-Xa
SCI Prophet-10
Rhodes Chroma
Rhodes Polaris
Roland JP-6 Europa
Roland JP-8
Roland MKS-80
Alesis Andromeda
Octave Voyetra-8
Questionable - Potentially phase locked to HF Master Osc:
Ensoniq ESQ-1
Ensoniq ESQ-M
DSI PolyEvolver (4 OSC)
DSI Prophet 12 (4 OSC)
Memorymoog
*Korg PS-3300
*Korg PE-2000
*Korg Lambda
Futuresonus Parva?
Oberheim OB-8
Oberheim OB-Xa
SCI Prophet-10
Rhodes Chroma
Rhodes Polaris
Roland JP-6 Europa
Roland JP-8
Roland MKS-80
Alesis Andromeda
Octave Voyetra-8
Ensoniq ESQ-1
Ensoniq ESQ-M
Last edited by HideawayStudio on Sat Mar 28, 2015 11:09 am, edited 13 times in total.
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
Re: 3-Oscillator Per Voice Polysynths??
Well Elka Syntex has 3 oscillators as well and fairly complex. Also are you referring to only true analogs or VA as well as you can find a lot of them with 3 osc : All Novation K/S station and Supernova, Alesis ION i think and Access Viruses.
- CfNorENa
- Gear: SEM | SH-2 | Prophet 5 | MKS-70 | Microwave XTk | Kronos || AD 202 | El Capistan | DP/4 | Eclipse | Rumour | PCM90
- HideawayStudio
- Band: Shortwave
EDIT: Synthex is 2OSC / voiceAlphacode wrote:Well Elka Syntex has 3 oscillators as well and fairly complex. Also are you referring to only true analogs or VA as well as you can find a lot of them with 3 osc : All Novation K/S station and Supernova, Alesis ION i think and Access Viruses.
Last edited by HideawayStudio on Sat Mar 28, 2015 10:38 am, edited 2 times in total.
- Automatic Gainsay
- Real name: Marc Doty
- Gear: Minimoog, 2600, CS-15, CS-50, MiniBrute, MicroBrute, S2, Korg MS-20 Mini, 3 Volcas, Pro 2, Leipzig, Pianet T, Wurli 7300, Wurli 145-A, ASR-10, e6400.
- Band: Godfrey's Cordial
Korg Lambda.
- Real name: John
- Gear: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, Oberheim SEM
If you count hybrid, there's the Ensoniq ESQ-1 and SQ-80.
- HideawayStudio
- Band: Shortwave
Interesting... this would therefore include PE-2000..Automatic Gainsay wrote:Korg Lambda.
Yup, hybrids allowed (love them!)commodorejohn wrote:If you count hybrid, there's the Ensoniq ESQ-1 and SQ-80.
Good call on the Ensoniq hybrids - I recently parted with my ESQ-M..
Last edited by HideawayStudio on Sat Mar 28, 2015 12:47 am, edited 1 time in total.
- Real name: Max
- Gear: T1, XV 5080, ES1, Zaquencer
If you count sub-oscillators, the Akai AX 80 has two DCOs and a sub. I think cost would have been a major factor in the development.
Edit: The Electron Analog Four, two DCOs + two subs also springs to mind.
- HideawayStudio
- Band: Shortwave
Sub-oscs not allowed - that's cheatingmax badwan wrote:If you count sub-oscillators, the Akai AX 80 has two DCOs and a sub. I think cost would have been a major factor in the development.
They need to be endowed with three free-running oscillators...
- GuyaGuy
- VSE Review Contributor
- Gear: YES PLEASE!
DSI PolyEvolver has 4
P12 has 5
P12 has 5
- Automatic Gainsay
DCOs shouldn't count, either. What the eff good are oscillators that are exactly in tune stacked atop each other?
Sub oscillators are divisions of oscillators... they are aligned in frequency and phase... and therefore don't matter at all as a "separate oscillator." You can't detune a sub oscillator. There is no point in bringing them up.
- Real name: Max
Fair enough.HideawayStudio wrote:Sub-oscs not allowed - that's cheatingmax badwan wrote:If you count sub-oscillators, the Akai AX 80 has two DCOs and a sub. I think cost would have been a major factor in the development.
I was just putting it out there.Automatic Gainsay wrote:DCOs shouldn't count, either. What the eff good are oscillators that are exactly in tune stacked atop each other?
Re DCOs: assuming enough mod sources, the DCOs shouldn't be discounted, but in general I agree.
- Z
I never seen a Synthex with 3 oscillators. Mine only has 2.Alphacode wrote:Well Elka Syntex has 3 oscillators as well and fairly complex. Also are you referring to only true analogs or VA as well as you can find a lot of them with 3 osc : All Novation K/S station and Supernova, Alesis ION i think and Access Viruses.
- Real name: Max
The Synthex can have four DCOs in layer mode, as can a Super JX - so they're both out.Z wrote:I never seen a Synthex with 3 oscillators. Mine only has 2.Alphacode wrote:Well Elka Syntex has 3 oscillators as well and fairly complex. Also are you referring to only true analogs or VA as well as you can find a lot of them with 3 osc : All Novation K/S station and Supernova, Alesis ION i think and Access Viruses.
- iphoenix
- Real name: Paul
Well if you're counting the Polyevolver & Prophet12, then I suppose you could count the Prophet VS.
4 oscillators , digital I know, but you could just use 3 oscillators all set to traditional analogue waveforms & turn the 4th off.
