Roland JX-3P issue?
synthboi
Roland JX-3P issue?
Post by synthboi » Fri Jun 05, 2015 9:34 pm
Hello, I'm new to the website, but I obtained a JX-3P a while back and found out that the sensitivity slider is really, really jumpy. I mean, REALLY jumpy. This has made the synth's tweakability very sucky, and purchasing a PG-200 (or even the clone) is just way too expensive, considering I purchased the synth itself for $175. I've tried using contact cleaner, but it still is really jumpy. Is there another way of fixing it easily?
Alex E
Gear: Jupiter-6, Juno-60, Polysix, Pro One, DX, Miami, M1r, Live 9, iMac MC309XX/A
Re: Roland JX-3P issue?
Post by Alex E » Sat Jun 06, 2015 4:25 am
That slider is probably just shot. If you're handy with a soldering iron, it shouldn't be too hard to replace.
This is the replacement part you need:
https://syntaur.com/Items/3344.html
Syntaur is out, but there's the specs.
The PG-200 sells these days for like $350... So a JX/PG combo for $525 isn't too shabby. ;)
soundcloud.com/vectron
Aaron2
Real name: Aaron
Gear: Pioneer: Toraiz SP-16
Elektron: AK, AR, MnM, MD, OT
DSI: Evolver, MEK, P08, Pro2
Korg: Arp Odyssey
Waldorf: Blofeld Keyboard
Post by Aaron2 » Sat Jun 06, 2015 6:34 am
Alex E wrote:The PG-200 sells these days for like $350... So a JX/PG combo for $525 isn't too shabby. ;)
The clone is even cheaper. It's about $240 on Juno http://www.juno.co.uk/products/mode-mac ... 553430-01/, plus shipping, so you're in for less than $300.
I can also confirm that Juno's shipping and service from the UK to the US is superb and fast. They often have things in stock that are hard to get in the US.
Alex E
Post by Alex E » Sat Jun 06, 2015 7:06 am
VERY cool. I didn't know Mode Machines made them now. :D
sam
Post by sam » Sat Jun 06, 2015 9:51 am
It's best to take out the slider and take it apart then clean it...should be ok..
Lam memorymoog.Sonic six.Vp330 mk1.SH101.OSCar.ARP odyssey..multivox mx3000.Solina stringsynth.polivox
ms20/50.Andromeda. OBX.
Prophet 5 Pro-one. Wasp.EMS AKS.
Tekhed66
Gear: Roland JD990
Roland JD800
Roland XV5080
Roland SH01A
Behringer DM12
Yamaha An1x
Studiologic Sledge 2
Korg Triton Rack
Korg M1
Korg Radias
Akai s5000
Band: The Creepy Uncles
Re: Roland JX-3P issue? - jumpy slider
Post by Tekhed66 » Sun Jun 07, 2015 2:27 am
I have just fixed up my JD-800 which is famous for its very dodgy and jumpy sliders...
I opened her up and used a can of compressed air to remove most of the dust and fluff and then used Deoxit F5 for faders to give it a good clean.... spray it on and work the slider back and forth for a bit and flush out any excess with more air.... the synth is perfect now and a DIY job saved me at least $300 in servicing fees.
I used to own a JX3P many years ago and it's a great synth ... it should be fairly simple to access the slider and give it a clean.
Not sure where you live but hopefully Deoxit or something similar is available.
If you open up the case, use the chance to give the case a good inspection... flush out the c**p that builds up under the keys and change the battery!!!
good luck
