Hello everyone, I recently acquired the beautiful Juno 6 for a very reasonable price (300$). However, it does have a few issues:
- Dead keys (about every 6)
- Transpose Key doesn't work
- Square Wave LED turns on sometimes (when not pressed)
- Sticky Sliders
So far these are the only issues I've encountered. Do you guys have any ideas about repairs? Anything I could do easily on my own. I'd say my soldering/DIY experience is about a 6/10.
Thanks.
Juno 6 Repairs
Re: Juno 6 Repairs
Also forgot to mention the Arpeggio seems to skip a step (usually every 4th step)
- ApolloBoy
- Gear: Korg ARP Odyssey
Korg Minilogue
Korg Monotron
Korg Volca Beats
Roland Jupiter-4
Roland JX-10
Squier P-Bass
Yamaha CS01
Yamaha CS-10 - Location: Campbell, CA
Re: Juno 6 Repairs
Sounds like most of those problems could be solved with a simple cleaning. The transpose button will most likely need to be replaced, and as for the square wave selector, it might be need to be replaced as well or it could be a faulty connection to the motherboard. Here's the service manual BTW: http://www.florian-anwander.de/roland_j ... ervice.pdf
Had: DX7, AX-60, SR-16, Yamaha TQ5, 01/WFD, Juno-106, MG-1, JX-03
Want: OB-6, Prophet 6, Jupiter-6
- madtheory
- Real name: Tomas Mulcahy
Re: Juno 6 Repairs
Dead key is most likely a failed voice chip. Have you de-soldered ICs before?
