It does indeed have regulated HT (around 180V) and regulated heater rails driving three JJ ECC83S (six triodes in total). The input and output are both balanced and on XLR and TRS. The last few built also had custom magnetically shielded torodial transformers.Mooger5 wrote:What was the goal of a high B+ for unity gain stages? More headroom, better linearity? I´ve seen on preamps as low as 12V. A single secondary powering up the plates and the heatersHideawayStudio wrote: There is gentle tube non-linearity to have but not wild overdrive. The tube B+ to all 6 triodes is around 200V (ie its not a low voltage "starved plate" design) and actually require a fair amount of signal to push them into distortion.
With the phaser enabled, if you push white noise into it and crank up the input gain control you get a very similar curious bubbling water effect as you get on the Small Stone which is quite cool. Most of these artefacts are from the OTA stages but the unit also runs with a tube in line even in bypass mode so it is possible to impart some more obvious tube overdrive if required. The inputs and outputs are balanced.![]()
The curves seem linear under 100V. Linear curves, what
Are the heaters supplies AC, or DC unregulated? I don´t notice any noise or hum. Sounds pretty clean to me!Its not exactly quiet though - with so much regeneration rattling around three phaser blocks tapped in series/parallel its not really surprising. The tube stages are pretty quiet in comparison with regulated HT and heater rails.
The EQ sounds nice as well.
And the Chroma has poly aftertouch on top of it all! What a fine synth, all these years under the radar. Thanks for sharing.
The tube stages are actually pretty quiet - the main issue has always been the tortuous regeneration paths tend to exacerbate the hiss levels significantly when the regen is turned right up. As you can hear, the phaser has quite a sheen to it and the balance was not killing too much of the HF response for the sake of taming the hiss.
As ever with analog effects, its all about making sure the gain structure is sensible and the unit is receiving a healthily strong signal.
Regarding the Chroma - just bear in mind that Poly A/T was an option and not so many have been retrofitted with pressure sensors over the years. That said, I have to say I have been extremely impressed by the sheer level of technical support offered to and among the Chroma community via the Rhodes Chroma website and user group:
http://www.rhodeschroma.com/
I wish to heck more vintage instruments were supported with such a noble open community spirit!
....the Synclavier not being one of them!!!!
