Ensoniq Transwaves - complete wave lists
- Real name:Unpronounceable
- Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
TG-33, K3m, Blofeld, Micron, Mopho, BS II, JV-1080 - Band:Eridani V
sure, just keep in mind the wavetables have dissimilar sample lengths.
- gridsleep
- Real name:Kurt
- Gear:Das Vorlagengehirn
- Band:Big Steam Horse
Re: Ensoniq Transwaves - complete wave lists
Ensoniq EXP-3 "The Urban Dance Project" what I believe to be the Transwaves in it:
The lists of voices in EXP cards 1, 3, and 4 are available at http://www.geocities.ws/asrxcite/ aka ASRXCITE.
I will attach (NOT; see below) a PDF (which I got from somewhere I can't remember) of the full list of voices. It has some with asterisks indicating "voices that contain components which can be synchronized to external MIDI clock." I am assuming this means Transwaves. I have acquired an MR Rack, and am planning on acquiring and installing an EXP-3 card at the beginning of next month. I will know for sure then whether I am correct.
The names are spelled as in the list attached (NOT; see below.) Also some of the patch numbers appear to be out of sequence or misnumbered so I cannot vouch for their sagacity. As I stated, I will only know for sure once I have an EXP-3 installed in the MR. (Update 2/23: has been purchased, is en route. Also awaiting ROM 1.53 upgrade chips, as my MR has OS 1.01 and the EXP-3 requires at least 1.50.) And as I just discovered one cannot simply walk into Mordor and attach a file to a post in this BBS because THERE IS NO OPTION FOR ATTACHING FILES TO A POST. I imagine it's a security feature but why then can you include a URL in a post text, which is just as dangerous? HM? Oh, but we have all this font c**p that nobody ever uses. Hooray for us. This is annoying.
Go to ASRXCITE if you want to see all the voices in EXP-3. It's a spreadsheet so be prepared. Also it doesn't have these particular patches marked as such. And actually, I decided WTF and simply uploaded the file to one of my Google drives. Here is the link:
PDF of Ensoniq EXP-3 voice list with Transwaves possibly marked
Previously, the column formatting in my list was screwed up. Then I discovered the preformatted text command. A little troublesome and underwhelming but it does the job.
eMagic SoundDiver 3.0.5 works perfectly in Windows 10 x64. I imagine the pared down Fizmo SoundDiver will also work just as well. If you can get your hands on either, you will be golden with the MR.
Name Bank Program Star Pad 29 0 Vocal Rez 29 3 Fazepad 29 6 Fireflies 29 7 Panning Pad 29 9 Phaser Pad 29 10 Stargaze 29 13 String Thing 29 18 Sync Sawed 29 19 Steppin 8ve 29 22 Sample Sync 29 26 Rezidence 29 34 Twsting 29 46 Trill Rez 29 50 1/8 Pad 29 53 SyncStringz 29 55 Accents 29 56 Gimme a 5th 29 57 TripleTech 29 58 PM NoizSync 29 60 Smoothly 29 62 Pressure Me 29 63 SawNoizSync 29 65 Step In It 29 70 SyncRaunch 1 29 71 SyncRaunch 2 29 72 Sync Sweepy 29 73 SyncVocoder 29 74 1/16 Noiz 1 29 77 SwampGas 1 29 79 Anarez Bell 29 87 Hey! 29 95 The Drone 29 96 LectrocPno 1 30 2 Blipped Out 30 10 LayerGruvs1 30 61 Sync Chirps 30 63 Sync Noiz 1 30 64 Granularity 30 65 Inharmonica 30 66 Unworldly 30 67 Sprockets 30 80 Weird Drone 30 91 Acid Trill 30 92 SqrNoizSync 30 93 Transgruv 1 31 96 Transgruv 2 31 97 Transgruv 3 31 98 Transgruv 4 31 99 Transgruv 5 31 100 Transgruv 6 31 101 Transgruv 7 31 102 Transgruv 8 31 103 Transgruv 9 31 104 Transgruv 10 31 105If these are all valid Transwaves, then an MR with an EXP-3 installed has 65% more Transwaves than a Fizmo. And whereas the Fizmo has only its 55 Transwaves and Saw, Square, and Fizdrums (1 kit,) the MR & EXP-3 has 91 Transwaves and 787 sounds (including General MIDI,) 397 of which are percussion, kits, or maps. The Fizmo can only play one sound, while the MR can play up to 16, layered, split, unison, however you want, with the SoundFinder catalogue system, and a ton of effects. The Fizmo has knobs. If you play the MR with a Novation SL MIDI keyboard, you will have more knobs, pads, sliders, buttons, and controls than you can use. They each can use the same SoundDiver editor. The MR has an extra headache in that it only has multitimbral Performances, not single voices, and while effects can be edited internally, an effect/chain (insert, not global) can only be attached to and saved with a particular sound externally, i.e. using SoundDiver. If you can live with that then you can proceed to make glorious sounds that would astound Beethoven and make Mozart green with envy.
That's really interesting, I didn't even know that the MR Rack had some of the Fizmo waves.
*starts searching for an MR rack*
Swiss Frank
ok done, and now i do actually want to know what you find
Swiss Frank
Sound Diver shows that an MR-Rack with EXP-1 (World), EXP-3 (Urban), and EXP-4 (Piano) expansion cards has the following 68 transwaves waves available, in ADDITION to the core MR-Rack waves. Furthermore, it seems that EXP-1 and EXP-4 have no transwaves (they're all acoustic instruments) so these are almost surely all from EXP-3.
With only the exception of "1K TEST SINE" ALL Fizmo waves are shared with the MR-Rack or the EXP-3. (13 are shared with the MR-Rack and 41 with the EXP-3.)
BASS REZ 2*
BLUE TRANCE
BRAINIAC*
CHIME-X*
CLAVINEX*
CLIX-POPS
COLOR WHEEL*
CYBORG*
ELVIS
FAT SQUAREZ*
FRANKENWAVE*
GET EVEN*
GREEN TRANCE*
HARMONIX*
HEY
HIHAT-X
JOLT
LIGHT YEARS*
LONG GONG 1
LONG GONG 2*
MERCURY BASS
MIRROR-X*
OPERETTA
ORANGE TRANCE
OVERTONES
POLYMOD SWEEP*
PULSEWAVEMOD*
QUITE ODD*
RAT BREATH X*
RED TRANCE
REZ LOOPS-2*
REZ POP ATAKS*
REZ SQUARE*
ROBOT SWEEP
SAMPLE & HOLD*
SAW REZ SWEEP*
SKY ROCKETS
SPARKLERS*
STEP UP*
STEPS*
STEPS REZ*
SYLLABLES*
SYNKING
TABLE-4-2
THANK YOU
TRAN-REZ BASS*
TRANS BLIPS
TRANS BOY*
TRANS E.PIANO*
TRANS-FRED
TRANS-GRESSOR
TRANZGRUV 01
TRANZGRUV 02*
TRANZGRUV 03
TRANZGRUV 04*
TRANZGRUV 05*
TRANZGRUV 06
TRANZGRUV 07
TRANZGRUV 08
TRANZGRUV 09*
TRANZGRUV 10*
TUBULAR-X*
U B RANDOM*
VODER-X*
VOWELS*
VOX SYN SWEEP
YELLOW TRANCE*
YODEL X
* shared with the Fizmo
BASS REZ 2*
BLUE TRANCE
BRAINIAC*
CHIME-X*
CLAVINEX*
CLIX-POPS
COLOR WHEEL*
CYBORG*
ELVIS
FAT SQUAREZ*
FRANKENWAVE*
GET EVEN*
GREEN TRANCE*
HARMONIX*
HEY
HIHAT-X
JOLT
LIGHT YEARS*
LONG GONG 1
LONG GONG 2*
MERCURY BASS
MIRROR-X*
OPERETTA
ORANGE TRANCE
OVERTONES
POLYMOD SWEEP*
PULSEWAVEMOD*
QUITE ODD*
RAT BREATH X*
RED TRANCE
REZ LOOPS-2*
REZ POP ATAKS*
REZ SQUARE*
ROBOT SWEEP
SAMPLE & HOLD*
SAW REZ SWEEP*
SKY ROCKETS
SPARKLERS*
STEP UP*
STEPS*
STEPS REZ*
SYLLABLES*
SYNKING
TABLE-4-2
THANK YOU
TRAN-REZ BASS*
TRANS BLIPS
TRANS BOY*
TRANS E.PIANO*
TRANS-FRED
TRANS-GRESSOR
TRANZGRUV 01
TRANZGRUV 02*
TRANZGRUV 03
TRANZGRUV 04*
TRANZGRUV 05*
TRANZGRUV 06
TRANZGRUV 07
TRANZGRUV 08
TRANZGRUV 09*
TRANZGRUV 10*
TUBULAR-X*
U B RANDOM*
VODER-X*
VOWELS*
VOX SYN SWEEP
YELLOW TRANCE*
YODEL X
that's very interesting...
- gridsleep
- Real name:Kurt
Excellent work. Thank you.Swiss Frank wrote:Sound Diver shows that an MR-Rack with EXP-1 (World), EXP-3 (Urban), and EXP-4 (Piano) ....
The voices with asterisks are supposed to be a list of voices where at least one of the layers of the voice was configured by Ensoniq to synchronize LFOs and Noise to the Drum Machine's rhythm, or to the 16 Track Recorder's tempo. Very few of those voices also have a Transwave layer.gridsleep wrote: ↑Tue Feb 20, 2018 7:09 pmEnsoniq EXP-3 "The Urban Dance Project" what I believe to be the Transwaves in it:
I will attach (NOT; see below) a PDF (which I got from somewhere I can't remember) of the full list of voices. It has some with asterisks indicating "voices that contain components which can be synchronized to external MIDI clock." I am assuming this means Transwaves....
I went through the EXP-3 voices as carefully as I could, using MidiQuest Pro 12 Demo and SoundDiver FIZMO. I found a number of differences, and I also went through all of the rest of the voices (I have an Ensoniq MR-61 with an EXP-1, EXP-3, and EXP-4) and created a comprehensive list which hopefully can be downloaded from the shared Google Drive link below.
At the same location, I also stashed a comprehensive list of MR & ZR voices where at least one of the layers of the voice was configured by Ensoniq to use a Transwave.
https://drive.google.com/drive/folders/ ... sp=sharing
That's really great work, thanks for compiling all that!
Dan Nigrin / Defective Records / https://defectiverecords.com
DP Editor (DP2/DP4/DP4+ editor/librarian), Fauxmo (Fizmo editor/librarian)
Cyclic, M185 & Klee Sequencers
DSX, MC-4 & MC-202 Hacks
General MIDI Player
General MIDI Player
- gridsleep
- Real name:Kurt
KitsapB, thanks for the continued work on this subject.
You're very welcome! Thanks for the inspiration to do this research. I learned a lot of things that were interesting to me while working on this.
