Page 1 of 2
The Definitive Severe Battery Damage Risk Synth Hotlist!
Posted: Tue Jul 18, 2017 10:51 am
by HideawayStudio
Having worked on a ludicrous amount of cherished vintage studio gear over the past few years I have seen a depressing and really quite alarming amount of carnage to pcbs in very nice kit due to severe battery leakage. This is especially the case where pcb mounted NiCd batteries such as the infamous Varta Mempac were employed.
What is becoming a concern to me is that from the outside most owners could be oblivious to the kind of damage that there is a very real risk of occurring on the inside. Whilst owners are polishing their beloved synths many are blissfully unaware of what is going on inside! Lets face it - it doesn't matter what sort of ritual you think is going to save your beloved old kit from this sort of thing... it needs to be checked out periodically and rectified if necessary!
Some of these batteries are now getting on for 40 years old!
As someone who used to head an electronic design team I find it really quite depressing that so many peer reviewers thought nothing of their guys using rechargeable pcb mounted batteries with a well understood failure mode in so many pieces of studio kit - some of which were extremely expensive! ..and its certainly not just limited to studio equipment - there are a ton of vintage computers also fitted with these darned things.
So for some time now I have wanted to start and maintain a definitive hotlist of what I and other contributors consider to be the most at risk from severe battery damage.
This is what I have so far. I have put these into two categories - firstly those that I consider to be at very real danger of severe battery damage and then those that can be prone to damage if the battery is left long enough in a discharged state. Please note that I appear to be singling out NiCds over Lithium backup batteries - this is because the chances of them leaking and causing severe damage are considerably greater.
..and its certainly not just less expensive/desirable gear either - I have had three AMS RMX-16s in the last few months alone with tracks on their CPU boards completely eaten away by leaking batteries!
At Risk of Severe Damage to PCB due to PCB Mounted NiCd Battery Leakage:
Synths:
  • Korg Polysix
    Korg Poly-61
    Korg Poly-61M
    Korg Trident I
    Korg Trident II
    OSCar
    Siel Opera 6
    PPG Wave
    Buchla 400
    Peavey SpectrumSynth
    Peavey DPM-V3
    Gem S2/S3/Equinox
    KAWAI SX-210
    KAWAI SX-240
    KAWAI SX-400
    SIEL DX-600
    ORLA/Böhm DSE 8, DSE 12 & DSE 24
    Böhm Dynamic 4x9
Drum Machines:
  • Roland CR-78
    Movement Computers MCS-2 (NASCOM II Computer)
    Böhm Digital Drums
    Linn 9000 (OMG the carnage!!)
    Linn LM-2
    Oberheim DMX
    Oberheim DSX
    Cheetah MD-16
    RSF SD140
Outboard:
  • AMS RMX-16
    AMS DMX-15
    Publison IM-90 "Infernal Machine"
    Lexicon M97 Super Prime Time
    Lexicon M200
    Lexicon 224X with Memory Option Board
    Korg SDD-3000
Misc:
  • Roland CSQ-600
Risk of Damage through extended discharge:
  • Memorymoog (Lithium but now of an age where severe damage to pcb is a very real possibility!)
    Rhodes Chroma (with original CPU board fitted - Drycells can leak onto CPU, front panel and stack pcbs)
    Roland JP-4 (NiCd battery mounted in floor of synth but can lead to corrosion to board through wires)
If anyone knows of any other synths specifically with pcb mounted NiCd batteries then let me know :geek:
Hopefully this list can become a sticky for reference.
LIST LAST UPDATED: 30/03/21
Re: The Definitive Severe Battery Damage Risk Hotlist!
Posted: Tue Jul 18, 2017 3:59 pm
by synthRodriguez
Add the Lexicon 224XL memory option board to the danger list for ni-cads with a charge circuit. Has 3 AA with solder tabs.
Posted: Tue Jul 18, 2017 7:15 pm
by ppg_wavecomputer
HideawayStudio wrote: [...] PPG Wave [...]
Oh yes.
Leaking is not the only problem as I had to learn -- those darn VARTA batteries produce corrosive fumes which also eat into adjacent boards.
Stephen
Posted: Tue Jul 18, 2017 10:49 pm
by Fatbenelton
CR78 and CSQ600 sequencer
Posted: Wed Jul 19, 2017 1:18 am
by ppg_wavecomputer
Dr. Böhm Digital Drums
Stephen
Posted: Wed Jul 19, 2017 9:18 am
by HideawayStudio
All excellent suggestions... list updated!
I'd forgotten about the Lexicon 224X - I only had one in a few weeks back and I was sufficiently concerned about that one (which had also started to leak!) that I removed the pcb mounted batteries and bolted a battery holder to the side of the chassis and remote mounted a fresh set of NiCds in their place.
Re: The Definitive Severe Battery Damage Risk Synth Hotlist!
Posted: Fri Jul 21, 2017 12:30 pm
by Mooger5
SCI Prophet 600?
Posted: Sat Jul 22, 2017 10:26 am
by HideawayStudio
Mooger5 wrote:SCI Prophet 600?
Most of the Sequential designs including the P600 utilised the larger solder in (often bright yellow) Lithium backup batteries (eg. BR-2/3A). Although these certainly have been known to leak once discharged for extended periods this usually takes a lot longer and so I've not yet made a list for this category. Similarly the solder tag variants of the infamous CR2032 "button cell Lithiums" found in hundreds of synth models such as the DX7 will eventually leak but this often isn't until the batteries are into very old age (or have been discharged unusually rapidly and then left for extended periods - eg. if there is an excessive battery drain due to a fault). It is not at all uncommon to find CR2032s and other variants with over 3 volts still present on them after 25 years in designs where the NVRAM current drain is low enough.
Posted: Thu Jul 27, 2017 8:08 am
by blueknob
Peavey DPM3.
Posted: Thu Jul 27, 2017 8:46 pm
by HideawayStudio
blueknob wrote:Peavey DPM3.
Many thanks for that - list updated.
Posted: Mon Aug 07, 2017 11:06 pm
by belltones
Kawai SX-210 has it just like the SX-240.
Posted: Thu Aug 10, 2017 9:03 am
by HideawayStudio
belltones wrote:Kawai SX-210 has it just like the SX-240.
Many thanks - list updated.
Posted: Tue Sep 05, 2017 3:04 am
by Love Canal Craig
The Emu Drumulator.
Posted: Tue Sep 05, 2017 9:07 am
by HideawayStudio
Love Canal Craig wrote:The Emu Drumulator.
The Drumulator uses a 2/3A lithium cell and not a rechargable NiCD so thankfully its not so prone to severe leakage.
Posted: Fri Feb 21, 2020 8:39 am
by JSmith
CR78 and CSQ600
