Hi there,
I have a Kawai K4 keyboard that I've opened up and identified 5 keys in one area that are no responsive. It's clear that something was spilled on it at one point because there is dried residual substance there.. it appears to not be highly corrosive as the stain doesn't show oxidation on anything in the area.. but ultimately they are not responding to key presses.
I only have 50% rubbing alcohol in my house and a can of deoxit (black label).
Would this be ok or should I stick with denatured alcohol (90% or higher, according to my research)..
I just want to clean the area, but don't want to risk harming the material either.
Thanks,
Caleb
ok to clean keyboard contacts with deoxit? (resolved)
part12studios
part12studios
Re: ok to clean keyboard contacts with deoxit?
Ok so i went with the 91% denatured alcohol. I figure Deoxit might be too aggressive for 1989 contact material.. the operation was a success thought one key seems to still be a little sketchy.. i'm going to have to give it another cleaning tomorrow and let it all sit overnight.. maybe its got a hit of moisture still in there from the alcohol.
Re: ok to clean keyboard contacts with deoxit? (resolved)
I've heard of Electrosolve contact cleaner but never seen or used it myself.
There might also be different types sold for various applications.
part12studios
I found these two links in my research that were useful for servicing the K4:
http://www.drosera.f2s.com/Servicing_K4.htm
http://www.bustedgear.com/repair_Roland ... cts_5.html
the key takeaway here when cleaning contacts is that the material unlike normal printed circuits and solder is that the material if cleaned to abrasive could separate that material from the board. try to use as little as possible when cleaning.
