tom Cadillac wrote:I'v got an MP7 - but am still coming to grips with it. I want to use it as a drum machine. Don't think I'v got anywhere near its potential.
But in many ways I don't like it. I bought it coz it was ridiculously cheap and I'm kind of stuck with it, as i can't imagine getting such a fancy piece of kit in the near future. So I want a sequencer for some drum tracks and this is what I'm using. Yet all the instant stuff on it - the paint by numbers music approach.....I thought there was no way to start from a blank canvas for a while. ! Also reading the maual i felt it was not quite accurate - like the 'amazing pads' - I find them not v responsive and where's the aftertouch?
Also I spent some time programming the ancient Emu MPS recently and got some amazing sounds out of it.
Comparing the two I can understand why Emu failed - because of just piling stuff onto the same basic structure. Personally I'v found the MPS more rewarding. Maybe its just easier and I havn't put the time into the MP7?
The pads are most definitely velocity sensitve, however, like most velocity sensitive controllers they can be made to act in a non-velocity sensitive manner. By default, this typically will be a matter of how a particular patch was programmed.
A lot of the beauty to the P2500/CS is it's modular nature....if you're into that sort of thing at least. To this same end, if you're not into that kind of thing, it can be a major detriment.
One of the things this results in is that the controls on the P2500 are not truly set as marked. If the cutoff knob happens to truly effect cutoff, that's courtesy of the maker of the patch, not because the knob is hardwired. Even the CC values that pertain to almost any given parameter are not hard set. This confused a mate of mine once, as I was working on a patch, I had told him I was dealing with what I wanted the equivalent of my modulation wheel to effect, and then much to his bafflement, when he started fiddling with the modulation wheel of an external controller that was being ran into the P2500/CS, he got no result. It wasn't that something was broken or not working, it was simply that I did not have what I wanted to serve as modulation wheel parameter set to correspond to the typical CC value for modulation wheel.
The P2500 is a pretty in depth and complex beast and has been so from the get go. I actually worked, along with a number of others, on the OS upgrades post version 1.0, and there was a TON that we added. The poster here would benefit from getting a PX7 as that was the only model made post our additions, and thus has a bit of a mapping flow labeled on the hardware itself in regard to how some of those new functions came to work, the other models do not however. This means there can be A LOT to commit to memory at times if one wants to really get the most out of P2500/CS's capabilities (notably as a sequencer).
