Crumar Polysynths
Analogue Crazy
Real name: Rob
Gear: Alesis Andromeda
Korg MS20 Mini
Korg Micro Preset
Korg DS-8
Yamaha Motif 7
Yamaha DX11
Post by Analogue Crazy » Wed Aug 22, 2007 12:56 pm
here is a white BIT 99 on ebay right now. Looks really cool.
A6 Andromeda, MS20 Mini, M500SP, DS-8, Motif 7, DX11,
themilford
Real name: David
Gear: Oberheim: OB-8, DSX, DMX, DXa, Yamaha CS-15, Akai AX-60, S612, Moog Taurus 3, Alesis MMT-8, HR-16, Fender Bass IV, Rickenbacker 620/6, Crumar Trilogy
Band: Season Finale
Re:
Post by themilford » Mon Dec 12, 2011 5:38 pm
Micke wrote:I believe both the Stratus and Composer use DCO's.
Sorry for the ancient bump... doing some digging and reading, may as well set the record straight.
The Trilogy and Stratus use TOS/Dividers... not sure that's quite the same as "DCOs".
The Polysynth section uses the following Curtis Chips:
6x CEM3310 EG, 6x CEM3320 VCF, 6x CEM3330 Dual VCA, 1x SSM2020 VCA
Also, from what I've read the Crumar DS-1 also has a strange sort of "hybrid" DCO as well. Not quite what we know as DCOs in synths like the Junos, Poly-800s and the like.
Bob Weigel sheds a little light here:
http://sounddoctorin.com/synthtec/synarch.htm
nathanscribe
Re: Crumar Polysynths
Post by nathanscribe » Tue Dec 13, 2011 2:06 pm
Necropost FTW!
Anyway, yes, Crumar were interesting. The Bit series uses a digital-clock-generated stepped sawtooth which is then shaped by analogue circuitry into square and triangle waves. It shares this idea with the Elka Synthex (both Mario Maggi designs I believe) but the Synthex is higher resolution. The Korg Lambda ES-50 is another unit I've seen working on a variation of this, beginning with top-octave divider technology with octaves summed at different levels to give an approximate sawtooth output.
The Bits sound good, and having 2 LFOs independently routable definitely helps in reducing the static feel of the raw waves.
