Hey guys. I was watching the Futurama movie, and there's a synth part with a really nice sounding lead that comes in at 0:42. You can check it out here:
Anyone know what it is, or what can make it? I like how smooth it is.
What synth/synths can make this synth line?
- meatballfulton
- Gear: Logic Pro X
Re: What synth/synths can make this synth line?
Square wave with portamento.
drummy
- Gear: Univox K-2 Mini-Korg 2
- Location: Northfield, Illinois or Milwaukee, Wisconsin (I go back and forth a lot)
That's what I thought., thanks for the reply Tried it on my Univox, but sounded a bit off. Even worse on my CS-5, so I thought a particular synth could do it better...meatballfulton wrote:Square wave with portamento.
- Synthaholic
- Expert Member
It's a square wave but it's filtered, so play around with the filter settings. Set cutoff to make it smooth and give it a touch of resonance and I bet you'll nail it pretty easily on any of your synths.
EDIT: It could be a triangle wave, or a filtered square wave, try both.
The reason it didn't sound like it on your minikorg is because the square wave isn't even square...go ahead and take a look at it with an oscilliscope...or a software oscilliscope. You need a true square waveform to get that sound. Also I think the pulse width is not set to exactly square in that clip.
Stuff I own:
X Station
ESQ-1
JX-8P
Poly 800
MaxiKorg 800DV
Elka Rhapsody 610
X Station
ESQ-1
JX-8P
Poly 800
MaxiKorg 800DV
Elka Rhapsody 610
