So I have been mulling over a 3030 for as long as I have been into the DIY synth thing and with the recent retirement of the original and the advent of the TM3030, I decided to get rid of my x0xb0x and replace it with a pair of these in a 1u rack. The boards themselves were 35 UKP ($67) which is pretty steep but given the sorry state of the green back these days, not much you can do. The boards are HASL plated (ROHS Compliant) so you realy want to get them stuffed within a couple months and take care not to touch any of the solder points. There are several options as far as which components you can use (vintage vs. modern), I opted to go with the vintage parts since I already had a fair amount of them on hand. Specifically, these were the 2sc1583 matched transistor pair, the 2sk30A-0 transistor, 2sk30-Y transistor, AN6582 Op amp. Of those, only the 2sk3A-Y and AN6582 are required, everything else can be replaced with a modern equivalent. Part costs were about $150 per board total. Assembly was about 3 hours for me. The digital side was designed by Colin Fraser of Sequentix fame and is brilliantly implemented. The smoothness of the slides and the accent works far exceeds the performance of the x0xb0x which was somewhat overbearing IMHO. Package wise, the PCB is quite small and I will be packaging two in a 1u rack.
The Sound
Based on my previous experience with 303 clones (x0xb0x, MAM MB33, Bass Station) I am easily the most pleased with the TM3030. Bass station was not really a clone and the MAM did do some things well but the direct comparison to the x0xb0x is the only one that really matters here. The VCO is identical on my scope with the flawed square being pretty much on point in both cases but sound wise, I would say the 3030 is more of an accurate "good" 303 square. VCF wise, I find the TM3030 to have a much more accurate resonance than both the original device and a stock x0xb0x, albeit it does have a greater range . Colin mentioned mods on the Oakley list to bring the resonance down to "stock" behavior but really having a little more "cowbell" is never a bad thing and it never really gets out of control musically like on the x0xb0x which I thought didn't do too well at hi resonance settings. Where the TM3030 really shines for me is the VCA and how it interfaces with the D/A. The designs here seem to depart a bit with the Oakley unit using a Intersil CA3080 OTA for the VCA vs. the BA6110 and the result is spectacular. Extremely clean, very low noise floor and most importantly an offset control which gets rid of the nasty click at the onset of a note which has been a issue with some x0xb0xes. Overall, I would say the TM3030 has a (dare I say?) warmer sound than the x0x. I dont have a BA662(the orginal R-Ohm Part) to try in the TM3030 but given the results with the 3080, I don't see any reason to. This is a rough clip showing the range of the controls with a square wave (everything dry with MFB502 for the drums). I'll get something more substantial up shortly
http://no-ho.com/tweak-01.mp3
Pictures
This is a mockup of the what the front panel will look like:
and the actual PCB
