Mono-only setups
stephen
Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8
Mono-only setups
Post by stephen » Sun Oct 12, 2008 11:22 pm
I've been having a ball with my SH-09 recently. With all the talk of mopho's and things, clearly monosynths are pretty cool.
Anyone have mono-only setups? If so, what attracts you to going the mono route, is it musical style or something else?
What synths would you put in a mono-only setup? Ummm.... notwithstanding huge modulars of course!! And microkorgs in unison mode don't count :roll: :D
Stephen(2)
Christopher Winkels
Re: Mono-only setups
Post by Christopher Winkels » Mon Oct 13, 2008 12:12 am
I'm thinking about it. Just a Little Phatty, an F-R XS and maybe one other synth.
Given that I'm not one for playing big jazz chords it makes perfect sense. That, and it's a lot easier on the wallet to stick with monophonic than a similarly equipped polyphonic instrument.
Automatic Gainsay
Real name: Marc Doty
Band: Godfrey's Cordial
Post by Automatic Gainsay » Mon Oct 13, 2008 12:51 am
I have nearly a mono-only setup.
Once I started multitracking the Minimoog, my polyphonic synths started vanishing. Multitracked vintage analog mono just sounds so incredibly good, I couldn't bear how plain latter-day polyphonics sounded.
I now multitrack monos almost exclusively. The CS-50 is still around because it doesn't scream "IT'S 1982!" every time I play a chord, and the interface is the best ever.
drummy
Gear: Univox K-2 Mini-Korg 2
Location: Northfield, Illinois or Milwaukee, Wisconsin (I go back and forth a lot)
Post by drummy » Mon Oct 13, 2008 6:55 am
Automatic Gainsay wrote:I have nearly a mono-only setup.
But isn't multi-tracking quite time consuming? Wouldn't it be much easier just using polyphonics?
Joey
Band: BLUSH_RESPONSE
Post by Joey » Mon Oct 13, 2008 7:05 am
mono only setups force you to be VERY very creative both in chord structure and the way you program your patches...
it'd be a fun challenge
i'd have these monos:
waldorf pulse (already do)
yamaha cs30
korg ms20 + SQ10
moog minimoog
arp odyssey
DSI MEK
that would cover everything I needed out of a mono setup
http://wearereplicants.com
Computer Controlled
Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
Band: Computer Controlled
Post by Computer Controlled » Mon Oct 13, 2008 7:11 am
All my synths are mono, except for the Ensoniqs. Which i don't use in recordings often.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
Black Tomorrow
Real name: kp Catalano
Gear: MG-1, Minilogue, Minibrute 2, V-Synth w/ VC1, Poly800, PSR740, Triton, SHS10, Stylophone, various random instruments, several VSTs.
Post by Black Tomorrow » Mon Oct 13, 2008 7:48 am
Joey, would the ARP Oddyssey count, being duophonic? Just pondering....
You can't synthesize love
Automatic Gainsay
Post by Automatic Gainsay » Mon Oct 13, 2008 10:10 am
Lots of musical activities are time consuming until you practice them.
Rarely does something easy turn out worthwhile.
Using monos for polyphonics results in a different and desirable sound (lots of oscs, all unstable, performed at different times with minor timing and pitch imperfections results in a wonderful warm, thick, choiry sound), and causes you to use chords you wouldn't normally use.
ned-ryarson
Post by ned-ryarson » Mon Oct 13, 2008 10:22 am
multitracking monos is great. my mek is used a lot for pads.
but ill always need a poly for composition, as most of my work involves chord progression.
nathanscribe
Post by nathanscribe » Mon Oct 13, 2008 10:36 am
I'd feel lost without a couple of polys around the place, but I do seem to have ended up with a few monos, unplanned. It's good to have different flavours of anything, so I've got a few from different families - SH, CS, Moog, etc. They complement each other well and inspire me differently, but they do take up quite a bit of space... it's got to the point now where if i buy another, I'll have to get rid of something, or at least put it in storage. :(
I like polys for the simplicity of not having to layer them. And personally, I quite like being reminded of 1982 when I play them. It was a fairly good year. :wink:
stephen
Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8
Post by stephen » Mon Oct 13, 2008 4:12 pm
There's some good ideas here, especially when it comes to encouraging greater creativity through "limitations".
Perhaps we could post some examples of mono layered pads, it certainly sounds a lot of fun. I'm on new baby duties right now, so it sounds like a good way to relax when I get a bit of spare time!! :)
Stephen(2)
Automatic Gainsay
Post by Automatic Gainsay » Mon Oct 13, 2008 4:51 pm
[email protected] wrote:but ill always need a poly for composition, as most of my work involves chord progression.
Good point! I rarely compose with a mono!
JSRockit
Post by JSRockit » Mon Oct 13, 2008 5:59 pm
I never intentionally use chords, so monophonic synths are my favorites. I only have one synth right now...the Monomachine...which can be polyphonic, but I only use it as a mono. I don't even know any chords on a piano style keyboard...only on Guitar.
nathanscribe
Post by nathanscribe » Mon Oct 13, 2008 6:23 pm
Automatic Gainsay wrote:Using monos for polyphonics results in a different and desirable sound (lots of oscs, all unstable, performed at different times with minor timing and pitch imperfections results in a wonderful warm, thick, choiry sound), and causes you to use chords you wouldn't normally use.
cf. OMD (first couple of albums) - they multi-tracked their humble Micropreset for thicker sounds.
Joey
Post by Joey » Mon Oct 13, 2008 7:49 pm
Black Tomorrow wrote:Joey, would the ARP Oddyssey count, being duophonic? Just pondering....
yes it can do duophonic, but its one oscillator per voice in duophonic mode, which is kind of boring...
i've used an octave CAT a lot (the odyssey ripoff kind) and didn't find the duophonic mode very great, and I imagine the one on the odyssey wouldn't be much better, so i'd probably never use it
