Octave Range: 2' 4' 8' 16' 32'
- garranimal
Noobish question maybe, but always wondered what exactly does this naming convention mean and where does it come from? Does 8' = 440 Hz proper middle C? It seems to follow that whatever 2' means, the next octave is double the value, 4', just like the 12-tone scale octave is double the hertz. What do I properly call the units (the apostrophe) of this convention. The synth manuals I have never make mention as its always assumed and taken for granted.
Andromeda gets away from this strange convention altogether and calls the oscillator frequency for what it is.
Re: Octave Range: 2' 4' 8' 16' 32'
The naming convention comes from pipe organs where different lengths (or is it diameters ? Anyways it's linked to the size) would give you different pitches. Which one is which,i don't know but should be fairly easy to find out.
- Z
Different pitch registers of pipe organs are measured in feet. Each octave is doubled in length.
- garranimal
LOL that's what I get for not really being into organs.
- Clavier
- Gear: A distraction.
- Band: Rhode Out West
Also, the shorter the pipe, the higher the pitch. While even number increments go in doubles by the octave, there are fractional increments too which play at a third, fouth, fith, seventh, etc. Middle C on the 8' setting is the same as middle C on a piano.
Hammond RT-2, Hammond M3, Hammond L-102, Rhodes mk1 suitcase 88, Sequential Circuits Prophet-5, Yamaha TX-802, Fender Twin Reverb, Leslie 45
Just found this page on the subject too, more in depth for those interested: http://www.die-orgelseite.de/fusszahlen_e.htm
Basically the 8 foot range is the "fundamental" one, so if you play middle C, you hear middle C (440Hz is the A above middle C). 4' is an octave higher, 16' an octave lower, & so on. As others have said, the convention comes from pipe organs, & a Hammond (or clone drawbar organ) has 9 footages to play with: 16', 8', 5 1/3', 4', 2 2/3', 2', 1 3/5'. 1 1/3', & 1' (though on most, with the exception of the Yamaha SK series, 5 1/3' is the second drawbar, & 8' the third). 5 1/3' is a fifth above 8', so if you play C you get the G above, 2 2/3' is a fifth above 4', 1 3/5' is a major third above 2', & 1 1/5' is a fifth above 2'.
If you find anything with a 64' range, make sure your speakers have a very good bass response, & move any fragile objects from nearby shelves & tables
My Spectrum goes down to 64' on both VCOs, and also has sub-octaves...
Casio PX-320, Odyssey Mk.1, Multiman-S, Andromeda A6, DW-8000, JD-800, Yamaha DX11, AN1x, & SK30, E&MM/Maplin Spectrum, Akai S3000XL, E-Mu Proformance 1, Esi-32, & Classic Keys, Alesis D4, Rickenbacker 4001.
- Clavier
I believe 64' is an 8Hz tone. That's lower than most subwoofers can go.
- OriginalJambo
- Gear: Check my sig
Not quite.Clavier wrote:I believe 64' is an 8Hz tone. That's lower than most subwoofers can go.
If A at 8' = 440 Hz then
16' = 220 Hz
32' = 110 Hz
64' = 55 Hz
A good sub should be able to handle 55 Hz no problem. In fact a good set of studio near-field monitors might even be able to go that low.
In fact a very crude formula to calculate all the fundamental frequencies of all footages playing an A note could be:
f(A)=440 x 2(^n)
Where n is the octave register represented by an integer (n=0 would obviously give a value of 440).
That's the A above middle C though, consider that a 5-octave keyboard has another 2 As below that, at (for 64') 27.5Hz & 13.75Hz. Get down to the bottom C on the same keyboard & you're down around 8Hz, definitely sub-audio; bring pitch modulation in & you're going to be giving your LFO a run for its money
- OriginalJambo
Ian S wrote:That's the A above middle C though, consider that a 5-octave keyboard has another 2 As below that, at (for 64') 27.5Hz & 13.75Hz. Get down to the bottom C on the same keyboard & you're down around 8Hz, definitely sub-audio; bring pitch modulation in & you're going to be giving your LFO a run for its money
Ah, that makes sense.
I don't think you'll be able to hear it right enough, but feeling it is another matter entirely. Brown note anyone?
So imagine my Spectrum at 64' on both VCOs with sub-octaves running, if I turned that up enough you'd probably feel it in Scotland
- Clavier
