I'm having trouble figuring out how to get it so that the mobius is sending cv and trigs to both oscs, i tried a 1/4" cable that splits to 2 1/4" but it would only work on one side, any ideas would be appreciated
thanks,
has anyone hooked up a yamaha cs15 to a FR mobius?
iwantaminimoog
Re: has anyone hooked up a yamaha cs15 to a FR mobius?
Yes I have, I was was just using it today in fact.
The splitter cable is what I use for mine, it should work no problem.
I would take a guess and say that your splitter is bad.
Also a fun trick is to just use Osc 1 then run it through filter 2, you can use the keyboard to trigger filter 2
and the envelope to contour the sound.
2 filters for twice the fun!!
Yamaha cs15 is great for Acid sounds......
Oberheim OB-8-Yamaha cs15-Akai MPC 2000xl-Akai S1000-Akai Ax-60 DSI Evolver-Ensoniq Esq-1-Trapkat midi drum trigger..
Your cable is probably an insert cable, one that splits stereo into two mono cables. You need a mono y cable.
- ianjhicks
- Gear: 808, 707, pro one, juno 60, jx3p, juno 106
- Band: Soft Metals
canyou find mono y cables at radioshack or is this something I'd have to build?
