TR808 Kick drum
FX23
TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 2:21 pm
hi, i have a TR808 and when listening to the kick drum it seems to change volume and decay for every beat, is this normal or do i have aq faulty machine?
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 3:03 pm
OK, after running the internal sequencer for 45 minutes the kick drum settled down, however when i tried the Groove Electronics midi retro fit im finding the kick drum jumps around in volume from +7db to -4db
Syn303
Gear: Quite a bit...
Band: Syn303
Re: TR808 Kick drum
Post by Syn303 » Sat Aug 01, 2009 3:27 pm
Your 808 is of no use to you, give it to me instead. The kick drum changing on every beat is normal, this is the beauty of an analogue drum machine.
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 3:41 pm
Then why the big changes in volume in midi mode compared to internal sequencer?
HideawayStudio
Real name: Dani Wilson
Band: Shortwave
Re: TR808 Kick drum
Post by HideawayStudio » Sat Aug 01, 2009 4:10 pm
Syn303 wrote:Your 808 is of no use to you, give it to me instead. The kick drum changing on every beat is normal, this is the beauty of an analogue drum machine.
Nope - I don't agree - yes some minor shift in volume and sound but this sounds like something more dramatic is going on. I agree it's a little odd the effect is only going on when you are using your midi interface. Is this the case when the kicks are played at a very slow tempo and the velocity is at a fixed level via midi?
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 6:02 pm
hi, yes ive tried fast and slow bpm and have set veloctity at max for all kick drum hits and yet some hits are very quiet. and this is only in midi mode, when triggered by the internal sequencer they at a more equal volume, i have made recordings of the two modes in sound forge and the difference is visible.
Solderman
Re: TR808 Kick drum
Post by Solderman » Sat Aug 01, 2009 6:08 pm
If you are using Trig mode instead of clock mode, won't the varying levels of Midi velocity cause different levels of volume? Here's The Manual.
--Solderman no more.
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 6:16 pm
Hi solderman, im using the same velocity for every hit.
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 6:20 pm
i havent checked to see if im in trig or clock mode but surely if i wasnt in trig mode it wouldnt be responding to note data?
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 8:03 pm
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 8:07 pm
FX23
Re: TR808 Kick drum
Post by FX23 » Sat Aug 01, 2009 8:08 pm
FX23
Re: TR808 Kick drum
Post by FX23 » Sun Aug 02, 2009 9:54 am
as you can see on the midi example the kick goes quiet for 3 beat at the ten second mark
HideawayStudio
Band: Shortwave
Re: TR808 Kick drum
Post by HideawayStudio » Sun Aug 02, 2009 12:04 pm
FX23 wrote:as you can see on the midi example the kick goes quiet for 3 beat at the ten second mark
Is the problem just on the kick or any other sound?
FX23
Re: TR808 Kick drum
Post by FX23 » Sun Aug 02, 2009 12:37 pm
just the kick drum, i wonder if it is possible that the retrokit is taking away voltage from the drum channel?
