Electribe Tubes
polyklinik
Gear: VCO, VCF, THC, LSD
Electribe Tubes
Post by polyklinik » Mon Dec 21, 2009 7:53 pm
Hi!
I saw a comment about changing tubes on the new electribes. Somebody recommend the Groove tubes 12AX7.
What are the experiences? Is it make any technical fault? :ugeek:
tallowwaters
Gear: LC-MS/MS
Re: Electribe Tubes
Post by tallowwaters » Tue Dec 22, 2009 3:24 am
Groove Tubes kind of suck, in my opinion. As far as cheaper stuff goes, I prefer EHX or Tung Sol.
Re: Electribe Tubes
Post by Stab Frenzy » Tue Dec 22, 2009 4:39 am
JJs for me.
tekkentool
Real name: Steve
Band: none currently
Re: Electribe Tubes
Post by tekkentool » Tue Dec 22, 2009 8:03 am
i'd go tung sol, ENGL tube's are really nice too
polyklinik
Re: Electribe Tubes
Post by polyklinik » Tue Dec 22, 2009 9:26 am
Anybody changed the tubes on his/her electribe? What's the result? I have EHX tubes....
stephen
Gear: Laptop
House Brick
Renoise
Loomer Aspect
FM8
Re: Electribe Tubes
Post by stephen » Tue Dec 22, 2009 9:29 am
polyklinik wrote:Anybody changed the tubes on his/her electribe? What's the result? I have EHX tubes....
Might be something over here http://www.electribe-forum.com/ :)
Stephen(2)
tallowwaters
Gear: LC-MS/MS
Re: Electribe Tubes
Post by tallowwaters » Tue Dec 22, 2009 3:21 pm
Truthfully, very little. I swapped in some supposedly quieter Mullards, then Tung Sol - nada. I suppose if you keep your tube gain cranked you might here some harmonic detail, but I use all 4 outs, so I tend to keep the tube gain down so as to avoid sonic discrepancies. I just put the EHXs back in so I could use the nicer tubes somewhere worth a damn.
I guess what I am saying is don't rush out and drop a lot of cash on a couple matched tubes (least of all vintage ones) in an attempt to make "warmth" or whatever. If you have some 12AX7s laying about, by all means, go nuts, but otherwise it's just snake oil (my opinion, of course, your mileage may vary).
brother
Gear: Ableton
Band: Tonica
Re: Electribe Tubes
Post by brother » Sun Dec 27, 2009 7:55 pm
polyklinik wrote:Hi!
had this problem as well..it sucked
mute
Re: Electribe Tubes
Post by mute » Mon Dec 28, 2009 6:02 am
tallowwaters wrote:Groove Tubes kind of suck, in my opinion. As far as cheaper stuff goes, I prefer EHX or Tung Sol.
the tubes that come with the esx/emx are EHX, and they've got nasty (useless) distortion starting at relatively low gain. If you want to use tubes for better gain so you can reduce your over all noise floor while also getting some decent tube warmth/shaping, the JJ's are the best option IMO. Get 3 or 4 of em in a pack deal off ebay for cheap (i got 4 for 25-30$'s) just so you can have different pairings to try till you get a good match. replacing them is cake.
korg forums is your best resource for this, some of the larger threads:
http://www.korgforums.com/forum/phpBB2/ ... hp?t=35175
http://www.korgforums.com/forum/phpBB2/ ... hp?t=31647
http://www.korgforums.com/forum/phpBB2/ ... hp?t=46452
Gregor Samsa
Gear: Too much (not enough).
Re: Electribe Tubes
Post by Gregor Samsa » Mon Dec 28, 2009 9:31 am
I use the JJ's. Seemed to take a bit of the nastiness and tinnyness out of the distortion- I found the original effect absolutely useless as previously mentioned. Could just be my perception though. I got mine from Eurotubes.com which has very good service. I agree with tallowwaters- I wouldn't go broke on tubes for the electribes, but I like what I have much better than what it came with. I can actually use the distortion now instead of keeping the gain all the way down to avoid the crappiness of the tubes.
tallowwaters
Gear: LC-MS/MS
Re: Electribe Tubes
Post by tallowwaters » Mon Dec 28, 2009 3:54 pm
I know that. I was simply saying that EHX would still be better than Groove Tubes trash. Regardless the tube path on the tribes is pretty much a gimmick.
mute
Re: Electribe Tubes
Post by mute » Mon Dec 28, 2009 7:12 pm
my response was aimed at the OP, but thanks for contributing.
Re: Electribe Tubes
Post by Stab Frenzy » Tue Dec 29, 2009 9:32 am
You guys know Sovtek, EHX, Svetlana, Tung-Sol and a whole lot of other brands are all made in the same factory on the same production line, they just test them when they're made and brand them according to how good they sound? With those ones you get exactly what you pay for.
tallowwaters
Gear: LC-MS/MS
Re: Electribe Tubes
Post by tallowwaters » Tue Dec 29, 2009 5:38 pm
Stab Frenzy wrote:You guys know Sovtek, EHX, Svetlana, Tung-Sol and a whole lot of other brands are all made in the same factory on the same production line, they just test them when they're made and brand them according to how good they sound? With those ones you get exactly what you pay for.
Yeah, but why does that matter? I was simply saying a cheap a*s Russian tube (EHX) sounds better than a cheap a*s Chinese tube (Groove Tubes).
Re: Electribe Tubes
Post by Stab Frenzy » Wed Dec 30, 2009 1:55 am
True, I was just adding to the edumacation quotient of the thread.
