Any manufactures of pressure sensative knobs?
Like aftertouch for a knob tweak.
I was thinking it would be nice to be able to adjust an second parameter by squeezing a knob as it's turned. In/out pressure would be nice as well to adjust a 3rd setting or to lock the squeezed setting.
Pressure sensative knobs?
- Sir Nose
- Real name: Bob
- Gear: Machinedrum, Octatrack, Moog LP, x0xb0x, Elka Solist 505, Simmons SDS-400
all that is good is nasty
nvbrkr
- Gear: An electric piano and analog synths.
Re: Pressure sensative knobs?
I'm sorry. I couldn't resist the temptation.
- Sir Nose
- Real name: Bob
The innuendo was totally unintended, but goes great with the recent kaossilator thread.
- Synthaholic
- Expert Member
I've seen knobs (usually on car stereos) where you pull the knob out to control a 2nd parameter with the same knob, then push it back in and you're back on the 1st.
On a synth with limited knob real estate, less commonly used functions could share a knob this way.
nvbrkr
Yeah, I was thinking where I've fiddled something like that. On my mom's car, of all places.
How about an X / Y -pad?
gordwiebe
- Gear: motif ES rack +cards, alesis fusion, E-MU PX7 + cards, siel MONO
not pressure sensitive, but... on the AN1X pushing the knob acts like a zoom function - giving you a smaller, more detailed sweep of the parameter. Pushing also calls up the actual value in the display without changing the value.
It would be nice if you could assign the push a job or value.
The z1 has multiple parameters assignable and scalable per knob for its controls under the screen
Meaning that, the filter cutoff can go from 54 to 78 at the same time the lfo 1 amt can go from 90 to 0 with up to 4 params on each knob if i remember, each with linear, expo or switch response.
Quite versatile not sure how many other synths have that available
Dont bother its not worth it!
- HideawayStudio
- Real name: Dani Wilson
- Band: Shortwave
Ahem.... the original Alesis Quadraverb had pressure sensitive buttons - the harder you pressed the faster it scrolled through parameters and values. Great idea... never really caught on.Synthaholic wrote:I've seen knobs (usually on car stereos) where you pull the knob out to control a 2nd parameter with the same knob, then push it back in and you're back on the 1st.
H.I.D.E.A.W.A.Y S.T.U.D.I.O
http://www.hideawaystudio.net
The Home of Novachord #346
http://www.novachord.co.uk
- cornutt
- Gear: 6th
I vaguely recall an old Polaroid camera that had a squeeze-sensitive knob. Can't remember now what it was for.
