Hey,
i have venturesome idea. I have Bit One with CEMs and badly damaged polysix - but with working ssm chips.
Tell me, bit one owners: are there any (or - if there are - how many) differences in electronics of early bit one factory ssm models and later, cem ones?
Is simple swap possible?
Crumar Bit One cem/ssm swap
- calyx93
- Gear: PPG Wave 2.2, μWave (x2), Roland JP6+V-Synth+S-220, SCI P5+600, Ensoniq SQ-80, Kawai K-3+K-3m, ARP Odyssey+Omni2, Emulator II+HD, Ensoniq Mirage.
Re: Crumar Bit One cem/ssm swap
Nope.
fantastic cat
So this is where my cunning plan fails...
- nathanscribe
- VSE Review Contributor
Life is never as simple as you want it to be. Not when electronics are involved.
- madtheory
- Real name: Tomas Mulcahy
Check the datasheets for the ssm and cem. Pinouts are different, different beasts entirely, AFAIK.
So a complicated swap is possible
- calyx93
I guess I should have added something along the lines of madtheory's response. It might be possible - I recall a thread from not so far back detailing the use of a SSM filter on a Juno 106. I do believe he only got one chip working, and that was a very complicated hack.
If only it were easy as plugging it in - if so, I'd have swapped between the CEM-3320s and SSM-2044s between my P5 Rev 3.2 and Wave 2.2 years ago. Sigh.
