I just bought one on wednesday and it should be here by monday, very excited
mopho module users?
colorbars
- Gear: Juno-60, ESQ-1, Mopho, Micron, Poly 61, MS2000R, DX-7, DX-21, M-VS1, ES-1 mkII, Monotron, ESI32, TR-505, EA-1
mopho module users?
Just out of curiousity... How do you use it in your setup? and what do you assign to your four assignable parameter knobs?
cartesia
- Expert Member
- Gear: Octatrack
Bass Station 2 - Band: TBA
Re: mopho module users?
Well, I had the tetra but I basically used it as 4 mophos sometimes..
I used the internal sequencer to sequence each part, I triggered the sequences manually from the 'push it' button..
Basically just doing minimal techno type stuff.. so the tetra's job was like so:
1 part bass
1 part stabby kinda thing.. varying from pad to short stabby rhythm
1 part weird twisting/evolving sounds
1 part whatever else I wanted for a track.
With the new OS changing combo mode it's pretty effective, although I would've liked the 'push it' button to start playing only on step 1 of any previous sequence playing.. at the moment you have to hit the button at exactlly the right moment.
The big thing from the new OS update IMO is the sequencer slew.. Letting you do smooth transitions from one step to another instead of 'stepping'
If you're into such things there's a guy who made a minimal track using just his mopho - of course he had to record 1 track at a time. I think search 'dogmatic minimal' on youtube.
1 part bass
- Computer Controlled
- Gear: SH-101 . TB-3 . TR-8 . Juno-1 w/PG-300 . TT-303 . Korg ES2 . Beatstep Pro . Pioneer RMX-500
- Band: Computer Controlled
I usually assign the 4 knobs to VCF EG amount, VCF EG Decay, and then whatever else i may need for that particular patch. As far as sequencing, i mostly sequence it externally, but i'll sometimes use the internal sequencer.
Synths:
Avalon Bassline . TB-03 . JU-06 . MX-1 . Blofeld . MicroMonsta . Akai S5000
Drum Machines:
TR-09 . TR-8
Drum Machines:
TR-09 . TR-8
