tips to making warm pads and strings on synths
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
The Curse Of Lilith Ratchet on TUBI
Band: view so cruel
Post by man-009 » Sun Sep 04, 2011 1:56 pm
any tips on making warm pads and strings? or does it depend on the synth being used? i have a waldorf blofeld kb.
garranimal
Re: tips to making warm pads and strings on synths
Post by garranimal » Sun Sep 04, 2011 4:29 pm
Strings....
- Two sawtooth waves slightly de-tuned, whether using osc fine pitch or small amount of bipolar lfo modulation (positive mod osc1, neg mod osc2) to pitch for chorusing effect.
- Lowpass Filter: around 75% or higher for brighter strings.
- Amp Envelope: 50-60% slow attack, decay/sustain on full, 50-60% slow release
- if a small amount of tremolo pleases then add another lfo source to amplitude, set lfo for delayed onset or controlled from mod wheel or aftertouch. Same trick could be used to achieve vibrato by assigning lfo to the overall pitch.
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Sun Sep 04, 2011 8:24 pm
very cool thanks...!
V301H
Band: The Characters
Post by V301H » Mon Sep 05, 2011 4:00 am
If your synth has the capability you can get a bowed effect at the beginning of a String sound by slightly modulating the pitch of one of the oscillators with an Envelope or Ramp Generator. Also, instead of a Sawtooth wave on both Oscillators try a slow Pulse Width Modulated Square Wave on one of the Oscillators to give the sound some motion for a Chorus-like effect.
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Mon Sep 05, 2011 5:29 am
wow..souds good. will try that thanks!
CS_TBL
Gear: All "In-The-Box"
Mainly FM8
Post by CS_TBL » Mon Sep 05, 2011 10:45 am
I'd mimic what happens with a real string ensemble: different players doing different things. One oscillator (a wee filtered saw, in most cases), a delicate random slewed LFO (also known as Analogue Feel in the Roland JV series) and a regular LFO on pitch, an envelope with a short attack on amplitude.
All this: 8 times, with different speeds for all LFO rates and envelope attacks. I did this exact thing on my Supernova2r (a performance made from 8 programs) and it sounds very convincing. Naturally, for pads: things don't need to be this realistic, but stacking randomly detuned oscillators with vastly different LFO rates and depths, panning positions and perhaps even tiny oscillator differences (sync?) is still key. You may have enough thickness stacking it 4 times..
FM8 vids
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Mon Sep 05, 2011 2:35 pm
another good idea. thanks guys! will try some today!
man-009
Real name: Timothy
Gear: MS2000
JP8000
blofeld
evolver
virus
AN1x
TG33
Band: view so cruel
Post by man-009 » Mon Sep 05, 2011 2:37 pm
i really try not to use presets. it's like cheating to me. and if i do, i always change it up a bit to make it my own.
cornutt
Gear: 6th
Post by cornutt » Mon Sep 05, 2011 3:43 pm
A lot of pad patches benefit from a slow-moving chorus effect (1 cycle per 4 seconds or slower). Also, keep the cutoff frequency down. To further warm them up, you might want to try a graphic EQ, with a bit of emphasis in the 500 Hz area and roll off everything above 4K.
