Synthesis types
White
Gear:Quite a few synths
Synthesis types
Post by White » Thu Nov 10, 2011 9:25 pm
OK, just out of interest, how many types of synthesis are there?
In my bedroom studio I have synthesizers with vector, wavetable, additive, FM, AWM, VA and PWM.
Duncan J. White + quite a few synths
http://www.myspace.com/stickman76590059
Yoozer
Re: Synthesis types
Post by Yoozer » Thu Nov 10, 2011 9:32 pm
PWM is not a synthesis type. AWM are samples through a subtractive engine, VA is subtractive, vector merely means you have a joystick to seamlessly blend between 4 (sample-based) sound sources which then usually go into a (usually) subtractive engine.
You can add granular and physical modeling (waveguide, Karplus-strong) to the list.
White
Re: Synthesis types
Post by White » Thu Nov 10, 2011 9:54 pm
Ah, I stand corrected.
Zamise
Gear:Rollhand P00
Band:Quantum-Source
Re: Synthesis types
Post by Zamise » Thu Nov 10, 2011 10:20 pm
Speech Synthesis.
CS_TBL
Gear:All "In-The-Box"
Mainly FM8
Re: Synthesis types
Post by CS_TBL » Thu Nov 10, 2011 10:27 pm
Does neuron synthesis fall under physical modelling?
FM8 vids
_seph
Real name:Joseph
Gear:Full OCP binary cyborg technology
Re: Synthesis types
Post by _seph » Fri Nov 11, 2011 6:41 am
although a variant of FM, Phase Distortion is also worth mentioning and the Analysis/Resynthesis method used by speech synthesizers and vocoders and found in Kyma is another honorable mention. Perhaps similar to this and Physical Modeling would be Roland's recent Articulate Phrase synthesis which debuted in the V-Synth GT and "models the performance behavior and nuance of acoustic musical instruments"
Real name:Unpronounceable
Gear:Ensoniq SD-1/32,SQR,VFX,ESQm
Band:Eridani V
Re: Synthesis types
Post by Ashe37 » Fri Nov 11, 2011 11:46 am
Yoozer wrote:vector merely means you have a joystick to seamlessly blend between 4 (sample-based) sound sources which then usually go into a (usually) subtractive engine.
Not always. The Yamaha SY-22 and TG-33 had samples on two poles and 2-op FM on two poles of the vector diamond, and had no filters.
Z
Gear:Bubble wrap, Styrofoam, boxes, packing tape
Re: Synthesis types
Post by Z » Fri Nov 11, 2011 2:05 pm
The SCI Prophet VS (probably the first vector synth) uses 4 digital wave oscillators.
Yoozer
Re: Synthesis types
Post by Yoozer » Fri Nov 11, 2011 3:35 pm
I used to have the SY-35 - but the synthesis methods are still FM and sample-based (albeit not subtractive, it didn't have any filters IIRC).
In case of the VS, the digital oscillators play back a very short sample - so it could be classified in the same group the DW8000 goes into.
The vector joystick mixes. You can record those, but it's not that radically different from plugging in 4 synths in a desk and then automating the volume fader movements - IMHO, of course.
Zamise
Gear:Rollhand P00
Band:Quantum-Source
Re: Synthesis types
Post by Zamise » Fri Nov 11, 2011 4:10 pm
I agree, vector synthesis is misleading and really more just a type of mixing. If its synthesis then scene morphing is also a type synthesis.
gridsleep
Real name:Kurt
Gear:Das Vorlagengehirn
Band:Big Steam Horse
Re: Synthesis types
Post by gridsleep » Sat Nov 19, 2011 2:03 am
Then there's spiral synthesis, as described in this very interesting article by Tracy Lind Petersen, which treats sound as a helix traveling through time, four dimensional in nature.
Dano
Re: Synthesis types
Post by Dano » Sat Nov 19, 2011 8:07 am
Here's a good link for examples of lots of synthesis types using a Nord Modular:
http://www.cim.mcgill.ca/~clark/nordmod ... k_toc.html
Gear:Eurorack, RYTM, Ultranova, many FX
Re: Synthesis types
Post by Stab Frenzy » Sun Nov 20, 2011 5:12 am
White wrote:OK, just out of interest, how many types of synthesis are there?
The problem with this question is it's like asking 'how many types of dogs are there? I know of brown dogs, black dogs, labradors and poodles.'
Vector synths can be subtractive, FM synths can have filters, etc.
