Hi.
Recently bought a JX-3P. Really like it.
The only problem is recording the on board sequencer. I am sending a rimshot from maschine to output 3 of my saffire pro 24 into the Seq Trigger In. It fires off the sequencer ok(ish) but there is a latency issue of about half a beat. I'm not sure if I'm missing something fundamental. I've tried using the ableton track delay to no avail. I've starting the sequencer then pressing play in ableton and I have tried starting the sequencer on beat but it skips.Anyone out there had this issue?
Problem with JX-3p onboard suqencer and Ableton
jocklefarm
Re: Problem with JX-3p onboard suqencer and Ableton
try using this instead: http://www.plosive.net/s/626_5v_trig-seq.wav
i assume you've tweaked/checked the latency(buffer) settings on your audio driver already?
