Can someone please explain RING MODULATION?
Dennis
Post by Dennis » Fri May 09, 2014 12:45 am
What is Ring Modulation and how do I use it?
I know it might be kinda hard to explain in a paragraph but I'll appreciate any help.
I'm kinda beginning to understand it, but still pretty confused, it's giving me headaches.
Thanks Guys
-Dennis
Re: Can someone please explain RING MODULATION?
Post by Stab Frenzy » Fri May 09, 2014 2:09 am
This link explains it pretty well: http://bit.ly/1l46BUr
Bitexion
Gear: Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Fri May 09, 2014 3:28 am
A slightly less dickish response, this video explains it pretty well with audio example.
What you hear basically is the sum of the two signals and the subtraction of the two signals at once. The sidebands.
That is why it sounds very dissonant when you sweep one of the frequencies. The further apart the two get, the more dissonant it sounds. When the two are very close in frequency you get a tremolo effect. Vangelis used this tremolo alot on the CS-80.
Post by Stab Frenzy » Fri May 09, 2014 3:47 am
That video was the second thing that came up from my link. :thumbright:
But seriously, it's not being a d**k to point out that the question somebody asked can be answered by typing that question into google rather than typing it into a new thread on a forum. It's a public service, it teaches the OP to find things out themselves and it stops the forum from filling up with pointless threads.
pflosi
Post by pflosi » Fri May 09, 2014 11:53 am
Ring mod can be implemented in different ways. Amplitude modulation, XOR (MS20), etc.
Solderman
Post by Solderman » Fri May 09, 2014 7:38 pm
In regards to amplitude modulation as a substitute, the drawback is that you can hear the modulator signal in the output, assuming it is in audio range, of course.
--Solderman no more.
Algorithm
Post by Algorithm » Fri May 09, 2014 7:51 pm
What does it take to add a ringmod in a DIY/mod situation? I remember seeing all sorts of ringmods on various cheap keyboards. I never understood the process of adding a ring mod though. What do you need besides the ringmod circuit?
Is it trash or treasure?
Dennis
Post by Dennis » Sat May 10, 2014 3:03 am
Yes I did Google it, yes I read the articles, that was sort of implied with "I'm kinda beginning to understand it, but still pretty confused." So thanks to the people who tried to make me feel stupid, definitely brightens my day.
It takes me some time to understand this stuff, so I came to the forum to get a straight answer.
Alright so I watched that video again.
So Ring Modulation uses one wave to modulate the frequency of the other?
So if I had 2 oscillators at different frequencies, and used Ring Modulation, it would use that first oscillator as the carrier for the second, multiplying the first frequency by the second as well as subtracting and adding the two?
I used Massive to give it a go, I used the Modulation OSC on a Sawtooth wave, now I understand the need for the pitch parameter on the modulation OSC, pretty happy.
Also, would I always be bound to using a Sine wave as a modulator signal, or is that just Massive?
I also heard of people using ring modulation with vocals, anyone have any idea how that works?
Thanks to the people who didn't come here to insult me
-Dennis
Real name: Unpronounceable
Band: Eridani V
Post by Ashe37 » Sat May 10, 2014 3:46 am
Depends on the synth. On a CS-80, the ring mod has its own sine wave oscillator as the modulation signal. *some* synths are bound to using just a sine wave as the modulation signal, others use whatever the waveform is set for (especially on VSTs, i guess the math gets pretty complex when the modulating signal has more than one harmonic).
commodorejohn
Real name: John
Post by commodorejohn » Sat May 10, 2014 4:54 am
Dennis wrote:So Ring Modulation uses one wave to modulate the frequency of the other?
Nope. It's closely related to amplitude modulation, which (as you may have guessed) uses one wave to modulate the amplitude of the other. The only difference between them is that with ring-mod you don't hear the modulator in the output, while with AM you do.
No, there's no multiplication involved. It simply produces frequencies equal to the sum and difference of the frequencies. By itself, with only two frequencies (i.e. plain sine waves,) that's not terribly interesting, but the important part is that it does that for all of the harmonics in the two waveforms - and since common synth waveforms like saw and square are made up of a whole series of sine waves at harmonic frequencies, ring-mod can produce quite complex series of harmonics. And since the exact series produced depends on the harmonic content of both oscillators and their relative tuning, there's a huge variety of things it can do.
Post by Stab Frenzy » Sat May 10, 2014 5:07 am
Dennis wrote:Alright so I watched that video again.
No not the frequency, the amplitude. Modulating the frequency is FM, which is similar in a way (gives you inharmonic results) but not ring modulation.
Dennis wrote:So if I had 2 oscillators at different frequencies, and used Ring Modulation, it would use that first oscillator as the carrier for the second, multiplying the first frequency by the second as well as subtracting and adding the two?
No, not multiplying, just adding and subtracting. Keep in mind that that example is a very simplified example which only considers sine waves (which contain a single frequency). If you use more complex waves like square, saw etc you introduce many more frequencies which make the results much more complex.
Dennis wrote:I used Massive to give it a go, I used the Modulation OSC on a Sawtooth wave, now I understand the need for the pitch parameter on the modulation OSC, pretty happy.
I don't use Massive so can't answer that question. By no means is a sine wave the only option as a modulator in general, although on some synths sine may be the only option.
Dennis wrote:I also heard of people using ring modulation with vocals, anyone have any idea how that works?
Same as any other signal. The results sound like the daleks voices in Dr Who.
Dennis
Post by Dennis » Tue May 13, 2014 2:48 pm
Very awesome answers, thanks for clearing this up for me.
Sorry for replying so late.
Band: Eridani V
Post by Ashe37 » Wed May 14, 2014 5:00 am
To the point where the guy that does the Dalek voice comes on stage and to rehearsals with a Moogerfooger ring mod.
