Random Synth Manual Humor
- briandc
- Real name:brian
- Gear:4 Midi controllers and anything linux! :)
Synth manuals sometimes come with a light sense of humor and colorful language. Here are a few quips I've found browsing synth manuals:
"You will need a strong stand to support both the MATRIX-12 and any additional punishment that you dish out." -Oberheim Matrix-12
"..Modern microprocessor technology takes the heartbreak out of finding a path through the electronic jungle!" -Crumar Bit 99
"We advise you to return the switch to the "ON" position (memory protected) immediately after storing new data, to prevent accidents and subsequent nasty surprises!" -Crumar Bit 99
"If you change your mind, and decide not to store the sound permanently, you can abort the storage process by pressing the "COMPARE" button. Cute, huh?!" -Crumar Bit 99
"Pedestrians--and anyone else who likes their hands free--will find a socket marked "PROGRAM ADVANCE" on the rear panel.." -Crumar Bit 99
"By now your curiosity is probably beginning to exert itself, and you may wish to start playing immediately." -Arp Axxe
"Be advised that in the excitement of creation patches tend to escape if not documented." -SC Prophet V
Others?
brian
Others?
brian
Feeling trapped behind Windows? Try linux: More than 500 flavors to choose from!
LinuxSynths.com
amSynth on Soundcloud
LinuxSynths.com
- Weirdofromouterspace
- Real name:Bodo
- Gear:MFOS SLMS+ & Ultimate, TTSH, DX7IID, DX21, Minibrute, Poly-800, microKORG, microSAMPLER, Volca Beats & Bass, JX-03, Tr-8, Kawai K1, Jasper
Re: Random Synth Manual Humor
Have a look at my sig
Don't forget to TURN ON THE SYNTHESIZER. Often this is the reason why you get no sound out of it. - ARP 2600
- pflosi
- Gear:more than 150 characters...
Not sure whether random Metasonix manual name calling is fair game here?
Not a synth, but still...
Yes, the swearword filter is easy to foolMetasonix G1000 manual wrote:It's a guitar amp, pussyboy. But it's unlike any guitar amp you've ever seen.
Because lots of guitar wankers want GAIN, we gave them TOO MUCH GAIN in the G-1000. I've personally seen idiots drive the input of a guitar amp with the SPEAKER OUTPUT of ANOTHER guitar amp. So, instead of pretending there is no guitarist fucknuttery in this happy world, we decided to offer an amp that's SELF-ABUSING. The G-1000 is not stable in all regimes, and it oscillates and motorboats in a variety of ways, depending on the control settings. Just like cascaded amps.
If you want to sound like an old Deep Purple album, you came to the wrong place, shitbrain.
- Uncle Screwtape
- Real name:Jay
- Gear:Access Virus Indigo
Alesis ion
Arturia MiniBrute SE
DSI Mopho
Novation KS4
Vermona DRM1 MkIII
Roland TR-707
Korg DDD-5
Korg Volcas (4) - Band:Uncle Screwtape
Some may not be meant to be amusing, or knee-slappers, but I got a chuckle that somebody felt they needed inclusion.
Vermona DRM1 MkIII:
"This product was introduced many years ago but the DRM1 is still being produced. Why? There are still musicians that do not own this product."
"To completely disconnect this apparatus from the AC mains, disconnect the power supply cord plug from the AC receptacle."
Dave Smith Manuals Regarding how a synth works:
"Fortunately, these days it is quite easy to find such resources on the Internet. If you want to learn the lingo and the basics, just try a search in Google (or the search engine of your choice), something like “analog synthesizer tutorial”. You’ll find plenty of good reading material."
Arturia Manuals:
"But that’s enough talk — plug in your new analog friend, and start vibrating the walls..."
"If you encounter any hearing loss or ringing in the ears, consult an audiologist immediately. It is also a good idea to have you ears and hearing checked annually."
"The manufacturer’s warranty does not cover service charges incurred due to a lack of knowledge relating to how a function or feature works (when the unit is operating as designed); reading the manual is the owner's responsibility."
"Do not use the instrument when there is a gas leak nearby."
Vermona DRM1 MkIII:
Arturia Manuals:
Your... affectionate uncle,
-Screwtape
-Screwtape
- garranimal
From the Blofeld manual, "Don't be surprised if you can't hear any difference when using Brilliance. Ask infants, dogs or bats to help you adjusting the oscillator brilliance."
The Drumulator manual opens up with, "You can use this manual to line bird cages, as kindling for starting a fire in the fireplace, as raw material for creating paper gliders, or most importantly, as a guide to help you get the most out of the Drumulator."
- Walter Ego
- Gear:Various noisemakers hidden around my home and classroom. And a great quantity of caffeine.
- Band:12"VS
The Ensoniq's ESQ-1 manual being pretty good-naturedly funny.
For example, re: the sequencer:
"...each time you record over any part of a Track, the ESQ-1 gives you the chance to listen to the new Track, and the original, before you decide which one to keep. Try that on a tape deck."
Also prophetic:
"One day you will switch the Power On, and instead of its usual wake-up message, the Display will read:
On "Bailing Out" of a program patch:
"You will lose the one you were working on before."
Examples of digitally recorded waveforms:
"Or to use another example -- take a recording of a human voice and play it back twice as fast. Does it sound like a human voice? No. What does it sound like? Chipmunks."
Then, in the same section, a comment about the names of waveforms:
"In the case of Sampled Waveforms especially, you should neither take them too literally, nor let yourself be limited by those Names...for example, if you find that with a certain Program the BASS waveform sounds like a harpsichord, or a kazoo, or whatever, go with it. Your ears are the only valid judge of what works."
There are probably more fun comments buried in the manual.
I guess what I like about it is that it's conversational and personal, rather than highly technical and inaccessible. It feels like there's actually another real person on the other end.
Also prophetic:
WARNING--BATTERY VOLTAGE IS LOW
SAVE DATA AND CONSULT OWNERS MANUAL"
Walter Ego
seamonkey wrote:I nominate this for STUPIDEST THREAD ever in the history of the internez.
Blofeld manual:
After you have bought your 128th Blofeld, please contact Waldorf Music. You will receive a personal device number that authorizes you to have dinner with our Managing Director. Be sure we invite you for some french fries at our favorite burger company.
from Akai S1000 manual
Remember Murphy's Law: "Anything that can go wrong, will". (The Law of Murphy the
Elder states: "Things that cannot go wrong, will".) Once you've made that perfect take,
there will be a power cut, someone will trip over a cable, or you'll press the wrong button
(we all do at one time or another - no-one's perfect). Seriously, though, saving raw
samples to disk as soon as you've made them is good standard operating procedure - you
lose less sleep that way. Also, if you make a mistake in the editing process, you can go
back to where you started from.
- briandc
- Real name:brian
Nice posts everyone!
brian
brian
LinuxSynths.com
LinuxSynths.com
- fh991586
- Real name:Francis
- Gear:Korg Kaossilator, MicroKorg,
Midines - Location:French Canada
Mackie mixers (CR1604 type & LM3204) have nice manuals too. With pictures of their workers!
Available for sale:
super_doraemon
- Gear:Moog Little Phatty, Micromoog, Arp Odyssey, Roland Juno-106, Alpha Juno 1, Microbrute SE(orange), Rhodes Stage 73, Octatrack, Prophet 6
- Band:Coral Bones, Pet Library
A gem from the Octatrack manual
- rhino
- Real name:bill
- Gear:keepers:
Kurzweil K2500x
Ensoniq TS-12
Yamaha SY-99
Alesis QS-8
Roland JD-800
Roland JX-10
Akai AX-80
Korg DSS-1
Moog Mini
Fizmo - Location:kentucky hills
Casio VZ-10m rack with AC power cord -
"Caution! Do not attempt to use this equipment under water."
- Confucius
- Confucius
- garranimal
I especially enjoyed reading about the VLZ faders getting dirty, described something to the effect as a "wiper that stumbles across crud."fh991586 wrote:Mackie mixers (CR1604 type & LM3204) have nice manuals too. With pictures of their workers!
User Manual Humour
This made me chuckle in the E-mu ESI 4000 user manual:
We suggest you practice cut, copy, and paste techniques on a spoken phrase. Samples of political speeches can be particularly amusing when subjected to cut and paste operations.
