Initializing a patch on a Jx10
- Peopleunderthesun
- Gear: Minimoog, Polymoog, Prophet 5, Composer, Multiman, Jx10 with Vecoven modifications, D50, Emax II HD, Dx7 MkI Supermax, MPC 5000
- Band: People Under The Sun
Sorry if this has already been covered but I can't seem to find it anywhere. Please tell me I am losing my mind and there is a patch initialization procedure for the Jx10. Thanks
Re: Initializing a patch on a Jx10
Hi,
On the JX-8P there is no such function and so I made an INIT patch myself. You might need to do that for the JX-10 also.
DCO on any of the waveforms, No Modulations at all. ENV2 controlling the VCA: A=0 D=40 S=40 R=0 (or something). Filter open, no Resonance; Save it.
Are you using a software editor like Ctrlr or Sounddiver? In that case it really is a piece of cake.
All the best,
Robin.
All the best,
Robin.
max badwan
- Real name: Max
- Gear: T1, XV 5080, ES1, Zaquencer
You are not losing your mind, and there is no initialisation routine on the JX 10.
I created an initial patch, which I called basic, and stored it on an M 16c, so I could quickly edit from scratch.
- Peopleunderthesun
Thanks so much for the replies. I'll have to make up an init patch tonight. I have tried to use ctrlr but I dont have a 3.0 jx panel. I've only been able to find one for the original and the 4.0 pwm version. They must have changed quite a bit between 3.0 and 4.0 because it doesn't respond at all
Did you take a look a super-jx dot com yet? There might be links there to editors that will work with the 3.0 of your JX.
- Peopleunderthesun
Don't forget that on the JX10 you have to create both a "tone" INIT and a "patch" INIT. The "tone" is a conventional JX8P patch, and the "patch" is the memory location for two JX "tones" layered or split on the JX10. Then, insert the two INIT tones into the single INIT patch, and you should be all set.
I used to own this synth, it was super nice for deep silky strings and pads... not so great for leads. But then that's what polyphonic analogs were best at anyway. I also had the PG-800 programmer... which would make creating an INIT tone easy-as-pie.
