Simple "waveshape-core" question
Grumblepig
Gear:Prophet 5 and a bunch of other fab things that aren't a Prophet 5...
Band:The Maude Squad
Post by Grumblepig » Mon Dec 12, 2016 2:45 am
What does it mean when an osc is described as "triangle-core?" The original Doepfer Dark Energy contains such. The DE II has a "sawtooth core" osc.
Cheers!
"Cerebral, memorable, melodic but also adventurous and inventive." - Monolith Cocktail
Yekuku
Gear:dk'tronics speech synthesizer :P
Re: Simple "waveshape-core" question
Post by Yekuku » Tue Dec 13, 2016 9:20 am
It means that the first waveform that the oscillator circuit produces is a triangle. All other waveforms ( saw , pulse etc) are produced by waveshaping the triangle.
It is all about sharing...
cornutt
Gear:6th
Post by cornutt » Tue Dec 13, 2016 9:49 pm
To add a bit to that: Most VCOs use a sawtooth core circuit. Other circuitry takes the sawtooth wave output by the core and transforms it into whatever other waveforms the VCO produces. Triangle core VCOs are said to have certain advantages in terms of waveform accuracy, but they are more difficult to design properly and require more components to implement, so they aren't used as often.
Grumblepig
Post by Grumblepig » Tue Dec 13, 2016 10:55 pm
Curious! Thanks for the replies. Is there a discernible difference in tone between the different types of oscs?
Broadwave
Gear:Kronos 2-88, Fantom 6, Novation Summit, ASM Hydrasynth, Modal Cobalt8, Behringer Odyssey, Behringer Poly D, BroadWAVE ARP 2600EX.
Post by Broadwave » Wed Dec 14, 2016 8:09 am
Grumblepig wrote:Curious! Thanks for the replies. Is there a discernible difference in tone between the different types of oscs?
Not enough to worry about, although I'm sure some purists here would have something to say about that ;)
Once you start looking at waveforms with a 'scope, you'll notice that Saw/Tri/Square waves are all slightly different when comparing synth manufacturers, but even this varies at different frequencies, so it's not a constant factor.
Another example is that, due to the design of the pulse voltage divider circuitry (5% resistors with no adjustment), the square waves on a Minimoog will NEVER be exactly 50% (more like 48% - It can easily be corrected, but you loose the character), whereas ARP, Roland etc have trimmers to produce an exact 50% duty.
What counts is the end result, not the source waveforms. The Minimoog design unintentionally introduces crosstalk between the VCOs, distortion in the VCF & VCA - all this adds up to produce "that" sound. An ARP 2600 has a much cleaner signal path with far less crosstalk & distortion so it has a totally different character from the MM.
Bitexion
Gear:Alesis Andromeda A6
Roland D-50
Creamware Minimax
Yamaha DX7s
Analogue Systems modular
Post by Bitexion » Wed Dec 14, 2016 8:28 am
I wonder why they left out PWM on the Minimoog.
Broadwave
Post by Broadwave » Wed Dec 14, 2016 8:42 am
Bitexion wrote:I wonder why they left out PWM on the Minimoog.
I presume, at the time, Moog were going for simplicity - Which sort of worked ;)
PWM can be added to the MM's VCOs, but you'll have to put those extra knobs and switches somewhere - I've done mods in the past which use a break-out box and ribbon cable, as it was the most elegant solution I could think of without drilling holes all over the front panel :shock:
commodorejohn
Real name:John
Gear:Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, Oberheim SEM
Post by commodorejohn » Wed Dec 14, 2016 9:25 am
I'm kinda curious to hear what that would sound like, as the Minimoog's square/pulse is so distinctive.
pflosi
Gear:more than 150 characters...
Post by pflosi » Wed Dec 14, 2016 6:21 pm
I'm guessing the reason is that the 901 also did not have a CV in for the PW. The 921 that does have it was released after the Model D. AG will come along soon and school us how PWM is not "real" synthesis and just there to "fake" two osc sounds - the Model D has three oscs, so no need for PWM according to that theory :mrgreen: Sorry Marc :thumbright:
WRT triangle core, some triangle core oscs in modular land only have a strange sort of "reversing" soft sync, which sounds kinda fun but can be a real pain for synced LFO applications... I guess hard sync is trickier with a tri core? Not entirely sure... Apparently, sine waves are easier to get clean with a tri core (although all Cwejman is saw core and those are the cleanest sines I know), which is somewhat essential for FM. AFAIK, the thru zero FM designs are also all based on tri core oscs.
Cheers :drinks:
Real name:Tomas Mulcahy
Post by madtheory » Wed Dec 14, 2016 6:34 pm
Maybe MuffWiggler is the place for this kind of, very interesting, debate?
Ya Mark's wrong though. Maybe PWM with an LFO is mostly used to fake a chorusing effect, but being able to adjust the pulse width to change the waveshape is incredibly useful. But that is rarely found on its own, because it is a simple step in most circuits to allow the shape to me LFO modulated.
I really hope there's a debate :)
pflosi
Post by pflosi » Wed Dec 14, 2016 6:43 pm
Interestingly, there is a PW control on the 901 - just no CV in.
Post by madtheory » Thu Dec 15, 2016 12:24 am
Interesting, I did not know that. But hang on, 901 is discrete transistors whereas MIniMoog has 741s instead, so they're not exactly the same are they?
Broadwave
Post by Broadwave » Thu Dec 15, 2016 8:00 am
madtheory wrote:Ya Mark's wrong though.
Oh boy, you're in trouble now :lol:
I didn't know Mr. Doty was so hung up about PWM. Modulating PW with envelopes, S&H and even Keyboard CV is vital to me - It's not all about the LFO ;)
pflosi
Post by pflosi » Thu Dec 15, 2016 1:06 pm
Yeah the Mini oscs are not exactly like the 901. But definitely based on it.
A 901 modded for PWM can be heard here: https://soundcloud.com/q-uazimodo02/mod ... ulse-width
Gear:Logic Pro X
Ableton Live
Nektar Panorama P6
Launchpad X
MOTU M2 interface
Post by meatballfulton » Thu Dec 15, 2016 3:40 pm
Broadwave wrote:I didn't know Mr. Doty was so hung up about PWM
This is an unsubstantiated rumor...
