Favorite Delay Pedal?
crystalmsc
Gear:uWaveXT,uQ,Pulse+;Ion;MiniBrt,Karma,Mntrb,Volcas,01R;Venom,NordModular,L2X;Evolver;JP8080,MKS70,JD990,D50,MC909,MC80ex,Microcon2;TG77,RS7k,AN200,AN1x
Band:Crystaline
Post by crystalmsc » Tue Jan 29, 2008 3:27 pm
I like the delay in the Korg AX1000G. Some of the delay is up to three seconds. My fav is the Echo Plus which is some kind of a tape echo simulation which sounds very nice. The delay alone could worth the unit admission. beside this, I like the delay of the Lexicon MPX100.
Kaossilatron - Voicillator
kvnvk
Post by kvnvk » Sat Feb 02, 2008 5:42 am
brian.only wrote:
kvnvk wrote:I've tried numerous delay pedals and devices over the years, but my absolute favorite continues to be the DOD/Digitech PDS/RDS line, mainly for the infinite repeat function and being able to smoothly pitch up or down a loop by tweaking the delay time knob.
Yeah they are really analog in that sense.
I'm a big fan of the sampling on the PDS 8000, the 2 second and 8 second have sprouted several songs. Its also a great 2nd looper for things you only want for a few bars.
Have you noticed any major differences sonically between the PDS and RDS or is it just the housing? I only own the PDS units.
I have both PDS and RDS delay units and to be honest I really can't descern any difference in sound quality between the rack and pedal versions, although I do have them set up as part of a longer effects chain.
gfriden
Post by gfriden » Fri Feb 15, 2008 1:50 pm
I'm surprised no one has mentioned the Maxon AD80 (300ms). It's a great, if perhaps a little over-priced little effect. Now, I have never used it with my synths, but it will give your guitar the meanest 50s style slap-back echo. Just in case you're into copying the Duane Eddy sound. :wink:
Art is not a copy of the real world. One of the damn things is enough.
Gear:Eurorack, RYTM, Ultranova, many FX
Post by Stab Frenzy » Fri Feb 15, 2008 4:32 pm
I think I'm gonna get a Hiwatt CTE with some money I've just come into, I could probably use a tape echo.
evening
Post by evening » Fri Feb 15, 2008 5:13 pm
There's a lot of bang-for-the-buck in the Line 6 DL4 pedals.
A couple of presets, tap tempo etc..
But the one thing I find stupid is that you cant have 100% wet signal in loop mode. Still a lot of fun though.
Things are not as they seem, nor are they otherwise.
MissionBrown
Post by MissionBrown » Tue Feb 19, 2008 8:17 pm
after killing then fixing my Malekko Heavy Industry 600ms Dark
I have to say that I am VERY happy with the quality of the echoes and overall timbre of the device.
Make sure you usea regulated power supply as it uses a MAX1044 chip which is only rated at 10v max.
they do a bright version too.
The dark is based on the Boss Dm-2 and the Bright is based on the Maxon AD-900
