routing audio/ rendering midi
femmespeaksever
Post by femmespeaksever » Mon Jul 16, 2007 2:39 am
When using softsynths, is it a very diffcult and frustrating task to use hardware compression,eg, or analog filters like the sherman? I was wondering because i was thinking about getting a open labs miko as a host for all VSTs, if doing this all in one computer is as easy as pie, it would save me alot of money from not buying the miko. Also when u render midi to audio, and your using good ad/da converters, do u get the sound of those converters on the softsynth afterwards.?
divineaudio
Gear: far too much.
Band: metria
Post by divineaudio » Thu Jul 19, 2007 5:21 pm
using hardware compression/effects is simple if you have a multi channel soundcard/interface. just assign your rendered audio track to a separate out --->through the compressor etc. --->back in to computer and record a new track with whatever processing you desire. watch your latency though.
as far as the sound of the converters, well... i'm not really sure what you are asking. :?
femmespeaksever
Post by femmespeaksever » Thu Jul 19, 2007 11:29 pm
When a midi track is rendered to create an audio track, is it getting the effect of the converters, as if you were sending a hardware instrument through the converters? I dont know if that made any more sense, hah.
divineaudio
Gear: far too much.
Band: metria
Post by divineaudio » Fri Jul 20, 2007 5:06 pm
yes it makes more sense. the answer is no.
femmespeaksever
Post by femmespeaksever » Fri Jul 20, 2007 8:22 pm
damn, thanks for the replys though, i didnt think any one would.
