Synthesizer Recording Techniques of the 70s and 80s
- midiCHICK6
I was listening to some New Wave recordings recently (specifically Duran Duran) and I noticed that the way synthesizers were recorded sounded noticably different compared to a modern synth recording.
I'm not talking about the fact that the synths were recorded to tape instead of a computer; I'm talking about the placement in the mix more than anything.
I guess my main questions are:
Were synths recorded in mono or stereo?
Were synths DI'd or mic'd with an amp?
It seems today that almost all synths are DI'd and a lot more sounds are recorded in stereo now!
MC6
MC6
Girls just wanna play synths.
KnowGood
- No Longer Registered
- midiCHICK6
- Synthaholic
- Expert Member
Re: Synthesizer Recording Techniques of the 70s and 80s
Many synths in the 70s/early 80s didn't have stereo outputs at all, or if they did, it was just for effects (chorus/flanger etc.) Sometimes they would record a synth part twice, once for each channel, to get a stereo effect, or use 2 synths, or run them through an effects box.midiCHICK6 wrote:Were synths recorded in mono or stereo?
It depends on the sound they were after. I'm sure it's been done both ways.Were synths DI'd or mic'd with an amp?
- RobotHeroes
- Gear: a toothed wheel that engages another toothed mechanism in order to change the speed or direction of transmitted motion
I think "he" is a "she". Alert the internets! We have an intruder.wiss wrote:I was assuming he meant DI box...piRoN wrote:Er... That is DI'ing.wiss wrote:I dont DI synths....its dirct to the mixing board...
"*Automatic Gainsay, you ignorant slut." - Primal Drive
"thanks guys. RobotHeroes, your avatar is the single most important thing on this website. ever. it reminds me that the world actually can be a good place." - rjd2
- midiCHICK6
The reason why I ask this is because it seems that some of the old synthpop mixes are a little less cluttered than modern day ones, at least in the sense of stereophony. Also, I know that mic'ing synthesizers can help add "early reflections" to the sound (natural reverb) which sounds quite nice.
When did stereo outputs become the norm?
- OriginalJambo
- Gear: Check my sig
I wonder if the cluttered sound you dislike is the heavy use of compression in modern music.midiCHICK6 wrote:The reason why I ask this is because it seems that some of the old synthpop mixes are a little less cluttered than modern day ones, at least in the sense of stereophony. Also, I know that mic'ing synthesizers can help add "early reflections" to the sound (natural reverb) which sounds quite nice.
hello darkness, my old friend
- shaft9000
- Real name: Dave
- Gear: Whips chains and a contract.
and those awful 'Maximizers' uuuughhhh....(ears bleed and ringing)otto wrote: I wonder if the cluttered sound you dislike is the heavy use of compression in modern music.
.svc350.memotron
.svc350.memotron
moogplayer
- Gear: minimoog, synare PS2, roland vp-330, monomachine, roland paraphonic rs-505, roland sh2, roland rs-09, boss dr-55, synsonics drums, moog prodigy
another method is to record both DI and amped signals to separate tracks. Sometimes I do this using an old Ampeg reverb rocket amp.
Multiplex
http://multiplexmusic.bandcamp.com
Muniq
http://muniq.bandcamp.com
Multiplex
Muniq
